B130-101-WP-1
B130-101-WP-1
    TRIPPLITE
    VGA OVER CAT5 EXTENDER WALLPLATE
B130-101-WP-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5/Cat6 Extender Kit, Wallplate Transmitter and Receiver, 1920x1440 at 60Hz Highlights ● Extends a 1920 x 1440 (60Hz) video signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N22201K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● RJ45 type wallplates allow you to use standard patch cable, eliminating the need for a 110 punchdown connection ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B130-101-WP-1 System Requirements Description Package Includes Tripp Lite's B130-101-WP-1 allows you to extend a 1920 x 1440 (60Hz) video signal up to 500 ft., or a ● Local (Transmitter) wallplate 1024 x 768 (60Hz) video signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as ● Remote (Receiver) wallplate Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal image quality between 500 and ● VGA "Y" cable 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. The remote (Receiver) unit features built-in ● Mini-Screwdriver for EQ/Gain adjustment ● Wallplate Screws ● (x2) External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.) ● Owner's Manual Equalization and Gain controls to adjust the video image. Kit includes local (Transmitter) and remote (Receiver) RJ45 type wallplates, which allow you to use standard patch cable, eliminating the need for a 110 punchdown connection. A VGA "Y" cable is included for use with the local unit, allowing for the connection of a local monitor. Ideal for digital signage situations, such as retail, schools, churches, etc. Features ● Extends a 1920 x 1440 (60Hz) video signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● A VGA "Y" cable is included for use with the local unit, allowing for the connection of a local monitor ● RJ45 type wallplates allow you to use standard patch cable, eliminating the need for a 110 punchdown connection ● The remote (Receiver) unit features built-in Equalization and Gain controls to adjust the video image ● Ideal for digital signage situations, such as retail, schools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332160195 Product Type Cat5/Cat6 Extender Kit Technology Stereo Audio; VGA/SVGA POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. PHYSICAL Color White Shipping Dimensions (hwd / in.) 2.20 x 6.20 x 10.20 Shipping Dimensions (hwd / cm) 5.59 x 15.75 x 25.91 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 CONNECTIONS Number of Ports 1 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B130-101-WP-1 价格&库存
很抱歉,暂时无法提供与“B130-101-WP-1”相匹配的价格&库存,您可以联系我们找货
