B140-1A0-WP
B140-1A0-WP
    TRIPPLITE
    DVI OVER CAT5 ACTIVE EXTENDER
B140-1A0-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/Cat6 Active Extender, Wallplate Remote Video Receiver, 1920x1080 at 60Hz, Up to 200-ft. Highlights ● For use with B140-002 or B140004 extender/splitter transmitter units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 150 ft., or a 1024 x 768 @ 60Hz signal up to 200 ft. ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Can further expand the range and number of monitors by adding B140-110 repeaters ● Compatible with all operating systems ● Plug and play, no software or drivers required ● Features a built-in Equalization control for adjustment of the video image ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-1A0-WP Transmit a DVI-D Single-Link signal up to 200 ft. away using a single Cat5e/6 patch cable Description The B140-1A0-WP is a receiver wallplate that is used with the B140-002 and B140-004 extender/splitter transmitter units, and it transmits a DVI-D Single-Link signal up to 200 ft. away using a single Cat5e/6 System Requirements patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp Lite's N202-Series). The B140-1A0-WP is compatible with all operating systems, and is plug and play, with no software or drivers required. It features a built-in Equalization control for adjustment of the video Package Includes ● B140-1A0-WP DVI Over Cat5 Active Extender Remote Wallplate Installation is simple. Connect a B140-002 or B140-004 transmitter (not included) to a DVI source using a ● Wallplate mounting hardware Tripp Lite P561-Series DVI cable (not included). Connect the B140-1A0-WP to a display using a Tripp Lite ● Screwdriver for adjustment of Equalization transmitter unit using a single Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 150 ft. ● 110 punchdown tool from the source, or a 1024 x 768 @ 60Hz signal up to 200 ft. ● Wallplate screws ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.) ● Owner's manual image. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. P561-Series DVI cable (not included). Finally, the receiver unit is connected to an RJ45 port on the Further expand the range and number of monitors by using a B140-110 repeater unit. Add up to four remote units (three repeaters and one active receiver) to each channel of the B140-002 or B140-004, for a total of 4 displays per channel. (An active receiver should be the last unit in a channel) A 1920 x 1080 @ 60Hz signal can be extended up to 125 ft. from each repeater to the next unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175 ft. Features ● Transmit a DVI-D Single-Link signal up to 200 ft. away using a single Cat5e/6 patch cable ● For use with B140-002 or B140-004 extender/splitter transmitter units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Extends a 1920 x 1080 @ 60Hz signal up to 150 ft., or a 1024 x 768 @ 60Hz signal up to 200 ft. ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Features a built-in Equalization control for adjustment of the video image ● Further expand the range and number of monitors by using a B140-110 repeater unit ● Add up to four remote units (three repeaters and one active receiver) to each channel of the B140-002 or B140-004, for a total of 4 displays per channel. (An active receiver should be the last unit in a channel) ● A 1920 x 1080 @ 60Hz signal can be extended up to 125 ft. from each repeater to the next unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175 ft. ● HDCP compatible ● Compatible with all operating systems ● Plug and play; no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332156716 Product Type Cat5/Cat6 Receiver Technology DVI VIDEO Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. PHYSICAL Color White Included Mounting Accessories Yes Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 11.43 x 6.99 x 2.54 CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 1 Side A - Connector 1 110 IDC Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B140-1A0-WP 价格&库存
很抱歉,暂时无法提供与“B140-1A0-WP”相匹配的价格&库存,您可以联系我们找货
