B125-101-60
B125-101-60
    TRIPPLITE
    HDMIEXTDRKITDUALCAT5/6150FT
B125-101-60 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Dual Cat5/6 Extender Kit, In-Line Transmitter/Receiver for Video/Audio, Up to 150 ft. (45 m), TAA MODEL NUMBER: B125-101-60 Highlights ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 150-ft. (45.72 m) using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Extends a 3D signal up to 125ft. (38.1 m) using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Supports 24-bit True Color (8bits per channel) ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● Local Transmitter and Receiver Units ● External Power Supply with NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A ) ● Screwdriver for Equalization adjustment ● Owner's Manual Transmit a HDMI signal up to 150ft, 1080p @ 60Hz using two Cat6 patch cables. Description Tripp Lite's HDMI Over Dual Cat5 Extender Kit is the perfect solution for those who need to extend a HDMI signal over a long distance over two Cat5/6 cables. ● When using 24Awg, Solid Wire Cat6 cable, a 1080p @ 60Hz (or 1920 x 1200) signal can be extended up to 150-ft. (45.72 m) from the source. ● When using 24Awg, Solid Wire Cat6 cable, a 3D signal can be extended up to 125-ft. (38.1 m) ● When using 24Awg, Solid Wire Cat5 cable, a 1080p @ 60Hz (or 1920 x 1200) signal can be extended up to 100-ft. (30.5 m) from the source. ● When using 24Awg, Solid Wire Cat5 cable, a 3D signal can be extended up to 75-ft. (22.86 m) Simply run two Cat5/6 cables between the local transmitter and remote receiver units, and plug in standard Tripp Lite HDMI cables to the HDMI source and the display. The B125-101-60 comes with both local transmitter and remote receiver units. DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio are supported, and it is compliant with HDCP, EDID and DDC. 24-bit True Color (8-bits per channel) is supported. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 150-ft. (45.72 m) using 24Awg, Solid Wire Cat6 cabling (Tripp Lite N202-Series) ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 100-ft. (30.5 m) using 24Awg, Solid Wire Cat5 cabling ● Extends a 3D signal up to 125-ft. (38.1 m) using 24Awg, Solid Wire Cat6 cabling, or up to 75-ft. (22.86 m) using 24Awg, Solid Wire Cat5 cabling ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Supports 24-bit True Color (8-bits per channel) ● Use Tripp Lite P568-Series HDMI cables to connect to HDMI source and monitor ● Equalization control dial for skew compensation ● Supports Lip-Sync Pass Through, and CEC pass through 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Green LED indicate power being received ● Orange LED indicates signal connection ● Compliant with the Federal Trade Agreements Act ( TAA ) for GSA schedule purchases Specifications OVERVIEW UPC Code 037332168023 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 150 ft via Cat6100 ft via Cat5e AUDIO Audio Input HDMI Audio Output HDMI Audio Specification 7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD INPUT 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Receiver end only (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 12mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Green (Connected), Orange (Activity) PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Box Receiver Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Receiver Unit Weight (lbs.) 0.05 Shipping Dimensions (hwd / in.) 1.50 x 6.50 x 8.50 Shipping Dimensions (hwd / cm) 3.81 x 16.51 x 21.59 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 Transmitter Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Transmitter Unit Weight (lbs.) 0.05 Unit Dimensions (hwd / cm) 6.03 x 4.45 x 1.9 Unit Packaging Type Box Housing Plastic 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 150 Max 480P Range (ft) 150 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 150 Max 640 x 480 Range (ft) 150 Max 800 x 600 Range (ft) 150 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 (2) RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; TUV; PSE; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B125-101-60 价格&库存
很抱歉,暂时无法提供与“B125-101-60”相匹配的价格&库存,您可以联系我们找货
