1000 Eaton Boulevard
Cleveland, OH 44122
United States
DVI over Cat5/6 Active Extender, Box-Style
Remote Receiver for Video, DVI-I Single Link, Up
to 200 ft. (60 m), TAA
Highlights
For use with B140-002 or B140004 extender/splitter transmitter
units
Supports DVI-D Single-Link
video resolutions up to 1920 x
1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz
signal up to 150-ft. (45.72 m), or
a 1024 x 768 @ 60Hz signal up
to 200-ft. (60.96 m)
Use 24AWG, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N202-Series, to achieve
maximum distance and
resolution
Can further expand the range
and number of monitors by
adding B140-110 repeaters
Compatible with all operating
systems
Plug and play, no software or
drivers required
Features a built-in Equalization
control for adjustment of the
video image
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B140-1A0
Transmit a DVI-D Single-Link signal up to 200 ft. away using a single Cat5e/6 patch cable
Description
The B140-1A0 is a receiver unit that is used with the B140-002 and B140-004 extender/splitter transmitter
units, and it transmits a DVI-D Single-Link signal up to 200-ft. (60.96 m) away using a single Cat5e/6
patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp
Lite's N202-Series). The B140-1A0 is compatible with all operating systems, and is plug and play, with no
software or drivers required. It features a built-in Equalization control for adjustment of the video image.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Installation is simple. Connect a B140-002 or B140-004 transmitter (not included) to a DVI source using a
Tripp Lite P561-Series DVI cable (not included). Connect the B140-1A0 to a display using a Tripp Lite
P561-Series DVI cable (not included). Finally, the receiver unit is connected to an RJ45 port on the
transmitter unit using a single Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 150-ft.
(45.72 m) from the source,, or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m)
Further expand the range and number of monitors by using a B140-110 repeater unit. Add up to four
remote units (three repeaters and one active receiver) to each channel of the B140-002 or B140-004, for a
total of 4 displays per channel. (An active receiver should be the last unit in a channel) A 1920 x 1080 @
60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the channel, or a
1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m)
System Requirements
Package Includes
B140-1A0 DVI over Cat5 Active
Extender Remote Unit
Mounting hardware
Screwdriver for adjustment of
Equalization
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5-ft. (1.52 m)
Owner's Manual
Features
Transmit a DVI-D Single-Link signal up to 200-ft. (60.96 m) away using a single Cat5e/6 patch cable
For use with B140-002 or B140-004 extender/splitter transmitter units
Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to
200-ft. (60.96 m)
Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance
and resolution
Features a built-in Equalization control for adjustment of the video image
Add up to four remote units (three repeaters and one active receiver) to each channel of the B140-002
or B140-004, for a total of 4 displays per channel. (An active receiver should be the last unit in a
channel)
1/4
Cleveland, OH 44122
United States
A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next
unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m)
HDCP compatible
Compatible with all operating systems
Plug and play; no software or drivers required
Specifications
OVERVIEW
UPC Code
037332156631
Product Type
Receiver
Technology
DVI; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
200
Max 1080P Range (ft)
150
Max 1280 x 720 (720p) Range (ft)
150
Max 1920 x 1080 (1080p) Range (ft)
150
Receiver/Transceiver Video Output
DVI-I
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
B140-110
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
200
Maximum Signal Range (m)
61
Maximum Signal Range Details
200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
2/4
Cleveland, OH 44122
United States
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
RJ45: Green (Connection), Orange (Data Transmission)
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
1
Form Factor/Mounting Options
Box; Wall-mount
Shipping Dimensions (hwd / in.)
2.20 x 7.20 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 18.29 x 16.51
Shipping Weight (lbs.)
1.08
Shipping Weight (kg)
0.49
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.54 x 6.35 x 9.14
Unit Packaging Type
Box
Unit Weight (lbs.)
0.43
Unit Weight (kg)
0.20
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
3/4
Cleveland, OH 44122
United States
Max 1024 x 768 Range (ft)
200
Max 480P Range (ft)
200
Max 1440 x 900 Range (ft)
200
Max 1080i Range (ft)
150
Max 480i Range (ft)
200
Max 640 x 480 Range (ft)
200
Max 800 x 600 Range (ft)
200
Max 1600 x 1200 Range (ft)
200
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B140-1A0”相匹配的价格&库存,您可以联系我们找货
