B125-101-60-WP
B125-101-60-WP
    TRIPPLITE
    HDMIEXTDRWALLPLATEKIT125FT
B125-101-60-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Dual Cat5/6 Extender Kit, Wallplate Transmitter/Receiver, Video and Audio, 1920x1200 1080p/60p, Up to 125-ft., TAA MODEL NUMBER: B125-101-60-WP Highlights ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 125 ft. using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Extends a 3D signal up to 100 ft. using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Supports 24-bit True Color (8bits per channel) ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● Local Transmitter and Receiver Units ● External Power Supply with NEMA 1-15P Plug( Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A ) ● Screwdriver for Equalization adjustment ● Wallplate screws ● Owners Manual Transmit a HDMI signal up to 125ft, 1080p @ 60Hz using two Cat6 patch cables Description Tripp Lite's HDMI Over Dual Cat5 Extender Wallplate Kit is the perfect solution for those who need to extend a HDMI signal over a long distance over two Cat5/6 cables. ● When using 24Awg, Solid Wire Cat6 cable, a 1080p @ 60Hz (or 1920 x 1200) signal can be extended up to 125 ft. from the source. ● When using 24Awg, Solid Wire Cat6 cable, a 3D signal can be extended up to 100 ft. ● When using 24Awg, Solid Wire Cat5 cable, a 1080p @ 60Hz (or 1920 x 1200) signal can be extended up to 75 ft. from the source. ● When using 24Awg, Solid Wire Cat5 cable, a 3D signal can be extended up to 50 ft. Simply run two Cat5/6 cables between the local transmitter and remote receiver units, and plug in standard Tripp Lite HDMI cables to the HDMI source and the display. The B125-101-60-WP comes with both local transmitter and remote receiver wallplates. DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio are supported, and it is compliant with HDCP, EDID and DDC. 24-bit True Color (8-bits per channel) is supported. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 125 ft. using 24Awg, Solid Wire Cat6 cabling (Tripp Lite N202-Series) ● Extends a 1080p @ 60Hz (or 1920 x 1200) signal up to 75 ft. using 24Awg, Solid Wire Cat5 cabling ● Extends a 3D signal up to 100 ft. using 24Awg, Solid Wire Cat6 cabling, or up to 50 ft. using 24Awg, Solid Wire Cat5 cabling 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Supports 24-bit True Color (8-bits per channel) ● Use Tripp Lite P568-Series HDMI cables to connect to HDMI source and monitor ● Equalization control dial for skew compensation ● Supports Lip-Sync Pass Through, and CEC pass through ● Green LED indicate power being received ● Orange LED indicates signal connection ● Compliant with the Federal Trade Agreements Act ( TAA ) for GSA schedule purchases Specifications OVERVIEW UPC Code 037332168030 Product Type Cat5/Cat6 Extender Kit Technology HDMI VIDEO Max 720P Range (ft) 125 Max 1080P Range (ft) 125 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A PHYSICAL Color White Shipping Dimensions (hwd / in.) 2.00 x 6.30 x 8.40 Shipping Dimensions (hwd / cm) 5.08 x 16.00 x 21.34 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 COMMUNICATIONS Max 1024 x 768 Range (ft) 125 Max 480P Range (ft) 125 Max 1440 x 900 Range (ft) 125 Max 1080i Range (ft) 125 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 480i Range (ft) 125 Max 640 x 480 Range (ft) 125 Max 800 x 600 Range (ft) 125 Max 1600 x 1200 Range (ft) 125 CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 (2) RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 (2) RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B125-101-60-WP 价格&库存
很抱歉,暂时无法提供与“B125-101-60-WP”相匹配的价格&库存,您可以联系我们找货
