B130-101S
B130-101S
    TRIPPLITE
    EXTENDERKITTRANSMITTERRECEIV
B130-101S 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA with RS232 over Cat5/Cat6 Extender Kit, Box-Style Transmitter and Receiver, 1920x1440 at 60Hz (discontinued) Highlights ● Extends a 1920 x 1440 (60Hz) Video and RS232 Serial signal up to 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Supports bi-directional communication ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule Purchases MODEL NUMBER: B130-101S Package Includes ● Local (Transmitter) unit ● Remote (Receiver) unit ● Mini-Screwdriver for EQ/Gain adjustment Description ● (x2) Mounting Hardware kits Tripp Lite's B130-101S allows you to extend a 1920 x 1440 (60Hz) Video and RS232 Serial signal up to ● (x2) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A) ● 3.5mm Male to DB9 Male adapter cable ● 3.5mm Male to DB9 female adapter cable ● Owner's Manual 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. The local (Transmitter) unit features an additional VGA port for the connection of a local monitor. The remote (Receiver) unit features built-in Equalization and Gain controls to adjust the video image. Includes mounting hardware for both local and remote units, allowing them to be wallmounted, rackmounted or pole mounted. Ideal for digital signage situations needing serial access, such as bar code scanners or touchscreen monitors. Features ● Extends a 1920 x 1440 (60Hz) Video and RS232 Serial signal up to 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Supports bi-directional communication ● The local (Transmitter) unit features an additional VGA port for the connection of a local monitor ● The remote (Receiver) unit features built-in Equalization and Gain controls to adjust the video image ● Includes mounting hardware for both the local and remote units, allowing them to be wallmounted, rackmounted or pole mounted ● Ideal for digital signage situations needing serial access, such as bar code scanners or touchscreen monitors ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule Purchases 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332151865 Product Type Cat5/Cat6 Extender Kit Technology VGA/SVGA POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5ft PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.20 x 10.20 x 7.60 Shipping Dimensions (hwd / cm) 5.59 x 25.91 x 19.30 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 CONNECTIONS Number of Ports 1 Side A - Connector 1 (2) HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 DB9 (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 DB9 (FEMALE) Side B - Connector 3 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B130-101S 价格&库存
很抱歉,暂时无法提供与“B130-101S”相匹配的价格&库存,您可以联系我们找货
