B126-1A0-U
B126-1A0-U
    TRIPPLITE
    HDMIACTIVEEXTENDER125FT
B126-1A0-U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Extender, Pigtail-Style Receiver for Video/Audio, USB Powered, Up to 125 ft. (38 m), TAA Highlights ● Supports high-definition video resolutions up to 1080p (@ 60 Hz) ● Supports stereo audio and HDCP ● Works with all operating systems and HDMI sources ● Built-in cable includes latching HDMI connector for a more secure connection ● Plug and play—no software, drivers or external power supply ● Built-in equalization control lets you adjust monitor image MODEL NUMBER: B126-1A0-U System Requirements ● Display with HDMI port Package Includes Works with Tripp Lite’s B126-Series transmitters to extend an HDMI audio/video signal via Cat5e/6 cable to an HDMI display up to 125 ft. Ideal for digital signs, schools, retail settings and trade show presentations. Description The B126-1A0-U HDMI over Cat5/Cat6 Active Extender works with Tripp Lite's B126-002 or B126-004 transmitter to extend an HDMI audio/video signal to an HDMI projector, monitor or television. It's ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. A latching HDMI connector on the built-in cable provides a more secure connection The receiver's built-in HDMI cable connects to the display. Cat5e/6 cable connects the receiver to the B126-Series transmitter (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202Series). Power is supplied by the included USB Micro-B to USB-A cable, which connects between the receiver and a USB port on the display or a USB wall charger. The B126-1A0-U can extend a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m) with full, rich stereo. Built-in RJ45 LEDs indicate the units are receiving power and a signal from the source. Built-in equalization control lets you fine-tune the image quality at the display. Easy to set up with no software or drivers to install. Works with all operating systems and HDMI sources. Features Extends HDMI Audio/Video Signals to an HDMI Display ● Extends a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m) ● Ideal for digital signs, trade shows, presentations, classrooms, churches and retail settings ● Built-in cable includes latching HDMI connector for a more secure connection ● Connects to transmitter with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● Supports stereo audio and HDCP ● Built-in equalization control lets you adjust the image Easy to Set Up and Use ● Plug-and-play engineering—no software, drivers or external power supply 1/4 ● B126-1A0-U Receiver unit ● USB Micro-B to USB-A cable, 3ft. (0.91 m) ● Screwdriver for adjusting equalization ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Powered via included USB cable ● Connects quickly to display with built-in HDMI cable ● LEDs indicate when units are receiving power and a signal from the source ● Works with all operating systems and HDMI sources TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332190253 Product Type Receiver Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 AUDIO Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Length (in.) 8.4 POWER Power Source Type USB Power Source Receiver end only (Included) Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) PHYSICAL Color Black Material of Construction Polycarbonate Number of Displays 1 Form Factor/Mounting Options Pigtail Rackmountable No Shipping Dimensions (hwd / in.) 1.30 x 6.14 x 4.80 Shipping Dimensions (hwd / cm) 3.30 x 15.60 x 12.19 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.4 x 6.1 x 5.2 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Signal Range (ft.) 125 Signal Range (m) 38 EDID Compatible Yes IR Remote Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 MICRO-USB B (FEMALE); RJ45 (FEMALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B126-1A0-U 价格&库存
很抱歉,暂时无法提供与“B126-1A0-U”相匹配的价格&库存,您可以联系我们找货
