B132-004A-2
B132-004A-2
    TRIPPLITE
    VGA + AUDIO OVER CAT5 EXT 4-PORT
B132-004A-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port VGA over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video/Audio, Up to 1000 ft. (305 m), TAA MODEL NUMBER: B132-004A-2 Highlights ● Splits a single VGA and Audio signal into 5 (1 local, 4 remote) ● EDID copy feature ensures optimal display compatibility ● Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● Can further expand the range and number of monitors by adding B132-110A repeaters ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes Features ● ● ● 4 Port Extender/Splitter local (Transmitter) unit ● 1 ft. VGA daisychain cable ● Mounting hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.) ● Owner's Manual Splits a single VGA and Audio signal into 5 (1 local, 4 remote) Increase the number of displays to up to 25 (1 local, 24 remote) by daisy-chaining up to six B132-004A2 units together ● A B132-100A or B132-100A-WP-1 remote receiver unit is required for each connected monitor ● Support for video resolutions up to 1920 x 1440 (60Hz) ● Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● EDID copy feature ensures optimal display compatibility ● The range and number of monitors can be further expanded by adding B132-110A repeater units ● Connect up to 4 remote units in a repeater chain (3 repeaters and 1 receiver), with a monitor at each location ● A 1920 x 1440 (60Hz) signal can be extended up to 500 ft. from the first repeater in the chain to the last receiver. A 1024 x 768 (60Hz) signal can be extended up to 1,000 ft. from the first repeater in the chain to the last receiver. ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Includes mounting hardware that allows unit to be wall mounted, rack mounted or pole mounted. ● Up to three B132-004A-2 units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB Extender/Splitter 19 in. rack-mount bracket ● Ideal for digital signage situations, such as retail, schools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332178435 Product Type Transceiver Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 Host Connector HD15 (FEMALE) VIDEO Video Input VGA Video Output VGA Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 500 Max 1080P Range (ft) 500 Max 1280 x 720 (720p) Range (ft) 500 Max 1920 x 1080 (1080p) Range (ft) 500 Max 1920 x 1200 Range (ft) 500 Transmitter Video Input VGA Transmitter - Number of Video Outputs 4 Transmitter - Local Display Output VGA Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 Maximum Signal Range Details 1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz) AUDIO Audio Input 3.5mm Audio Specification Stereo Audio POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power); RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 4 Optional Mounting Accessory Notes Up to three transmitters local units can be mounted in 1U of rack space using a Tripp Lite  B132-004RB  Extender/Splitter 19in rackmount bracket Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount; Rackmount Shipping Dimensions (hwd / in.) 2.50 x 6.30 x 10.10 Shipping Dimensions (hwd / cm) 6.35 x 16.00 x 25.65 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 1.200 x 5.000 x 4.000 Unit Dimensions (hwd / cm) 3.05 x 13.46 x 9.91 Unit Packaging Type Box Unit Weight (lbs.) 0.85 Unit Weight (kg) 0.39 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range -4 to 158 (-20 to 70 C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 1000 Max 480P Range (ft) 1000 Max 1440 x 900 Range (ft) 500 Max 1080i Range (ft) 500 Max 1920 x 1440 Range (ft) 500 Max 480i Range (ft) 1000 Max 640 x 480 Range (ft) 1000 Max 800 x 600 Range (ft) 1000 Max 1600 x 1200 Range (ft) 500 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No USB Extension Support No CONNECTIONS Number of Ports 4 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 HD15 (FEMALE) Side B - Connector 3 3.5MM (FEMALE) FEATURES & SPECIFICATIONS Driver Required No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B132-004A-2 价格&库存
很抱歉,暂时无法提供与“B132-004A-2”相匹配的价格&库存,您可以联系我们找货
