B140-1A1-WP
B140-1A1-WP
    TRIPPLITE
    DVI EXTDR WALLPLATE CAT5/6 200FT
B140-1A1-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/Cat6 Active Extender Kit, Wallplate Transmitter and Receiver, 1920x1080 60 Hz, Up to 200 ft. (60 m), TAA MODEL NUMBER: B140-1A1-WP Highlights ● DVI Single-Link video over Cat5e or Cat6 cabling ● Easy RJ45 connection on back of wallplates ● Equalization control for the sharp display quality ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements ● DVI Video card and DVI Monitor Package Includes Extend a DVI Digital Single-Link signal up to 200ft @ 1024 x 768 or 150ft @ 1920 x 1200 over inexpensive Cat5e / Cat6 cabling. Features ● 2 piece kit includes both local transmitter and remote receiver wallplates ● Extend a DVI-D Single-Link signal up to 200 ft. at 1024 x 768 (60Hz), or up to 150 ft. at 1920 x 1200 (60Hz), when using 24Awg, solid wire Cat56 cabling. (Tripp Lite N202 Series Patch Cables) ● Built in equalization control for the sharp display quality ● Easy RJ45 patch cable connections ● No software or drivers required ● HDCP and DDC compatible ● Compatible with all operating systems ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332168092 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 1/4 ● B140-1A1-WP Local Wallplate ● B140-1A1-WP Remote Wallplate ● (2) External Power Supplies with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● Wallplate screws ● Screwdriver for Equalization adjustment 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-I Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-I Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators TX & RX: Power (Green); Activity (Orange) PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Receiver Unit Dimensions (hwd / in.) 4.5 x 2.75 x 1 Receiver Unit Weight (lbs.) 0.57 Shipping Dimensions (hwd / in.) 2.20 x 6.20 x 8.40 Shipping Dimensions (hwd / cm) 5.59 x 15.75 x 21.34 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Transmitter Unit Dimensions (hwd / in.) 4.5 x 2.75 x 1 Transmitter Unit Weight (lbs.) 0.57 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-1A1-WP 价格&库存
很抱歉,暂时无法提供与“B140-1A1-WP”相匹配的价格&库存,您可以联系我们找货
