B140-202
B140-202
    TRIPPLITE
    DVIMATRIXSWITCH2X2200FT
B140-202 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2x2 DVI over Cat5/Cat6 Matrix Splitter Switch, Video Transmitter, Up to 200 ft. (60 m), TAA MODEL NUMBER: B140-202 Highlights ● Share two DVI sources between two monitors ● Supports DVI Single Link computer resolutions up to 1920 x 1200 @ 60Hz ● Transmits over inexpensive Cat5e/6 cable up to 200 ft. ● Plug-and-Play ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements ● DVI video cards and DVI monitors Package Includes ● B140-202 Local Transmitter Unit ● External Power Supply with NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● Mounting Hardware Share two DVI video sources between two monitors ● Remote Control ● Supports DVI Single Link computer resolutions up to 1920 x 1200 @ 60Hz ● Owners Manual ● Allows either input to be routed to either output, or the one input signal to both outputs ● Transmits over a single Cat5e/6 cable to a remote monitor up to 200-ft. away ● HDCP and EDID compliant ● Plug-and-Play ● A B140-Series remote receiver is needed at each monitor ● Active (powered) and Passive (non-powered) Receivers available ● Use 24AWG Solid Wire Cat5e/6 patch for maximum video performance ● Further expand the range and number of monitors with B140-110 Daisy-Chain Repeaters ● Compliant with the Federal Trade Agreements Act ( TAA ) for GSA schedule purchases Allows up to 2 DVI video sources to be independently switched to 2 UTP outputs Features ● Specifications OVERVIEW UPC Code 037332175861 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 Host Connector (2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) VIDEO 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-I Transmitter - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators Power (Green); Output 1, 2 (Orange); RJ45 ports: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 6.30 x 2.50 x 8.30 Shipping Dimensions (hwd / cm) 16.00 x 6.35 x 21.08 Shipping Weight (lbs.) 1.60 Shipping Weight (kg) 0.73 Unit Dimensions (hwd / in.) 1.200 x 5.000 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 12.7 x 9.91 Unit Packaging Type Box Unit Weight (lbs.) 0.8 Unit Weight (kg) 0.36 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 1 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-202 价格&库存
很抱歉,暂时无法提供与“B140-202”相匹配的价格&库存,您可以联系我们找货
