B116-004A
B116-004A
    TRIPPLITE
    DVISPLITTER4-PORT1920X1200
B116-004A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port DVI Splitter with Audio and Signal Booster - Single-Link DVI-I, 1920 x 1200 (1080p) @ 60 Hz, TAA MODEL NUMBER: B116-004A Highlights ● Transmits up to 81-ft. (24.68 m) for digital signage in bars, offices, classrooms, trade shows, etc. ● Capable of cascading up to 64 total displays in sophisticated applications ● Supports HD resolutions up to 1920 x 1200 (@ 60 Hz) for crystal-clear 1080p video ● Easy plug-and-play operation for immediate connection right from the box ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Applications 1 x 4 DVI splitter transmits 1080p video and audio from a DVI source to 4 DVI display devices at the same time. ● Displaying a digital menu from a PC on monitors in a restaurant or bar ● Connecting HDTVs to the same cable box, media server or DVD player for sports or movies ● Giving a presentation on large projectors or monitors in a lecture hall ● Creating digital signage for an office lobby, healthcare waiting room or airport Features DVI Splitter Transmits HD Video + Audio to 4 DVI Displays at the Same TimeRecommended for displaying digital signage in classrooms, healthcare facilities, churches, offices, restaurants, bars and trade shows, this high-definition DVI splitter is quick and easy to install. It connects to a DVI source device, such as a computer, cable box/DVR or DVD player, and transmits an audio/video signal to four DVI monitors, projectors or televisions simultaneously. You can cascade together up to three levels of splitters, which expands the total number of connected displays to 64. Maintains 1920 x 1200 Video Resolutions with Rich Stereo SoundThis DVI splitter transmits a DVI-D single-link video signal with 3.5 mm audio to four sets of monitors and speakers. It supports computer video resolutions up to 1920 x 1200 and high-definition resolutions up to 1080p. The distance between the splitter and the DVI source must not exceed 16-ft. (4.88 m) Supports High-Definition Video Signals up to 81-ft. (24.68 m)A built-in booster expands the distance between the splitter and the connected displays past the recommended 16-ft. (4.88 m) DVI signal limitation. The B116-004A distributes source video resolutions between 1600 x 1200 (at 60 Hz) and 1920 x 1200 (at 60 Hz) up to 49-ft. (14.93 m) between the splitter and the connected display/speakers. However, by dropping down to source video resolutions below 1600 x 1200 (at 60 Hz), which includes 1080p, the distance between the splitter and the connected display/speakers increases to 65-ft. (19.81 m)—a total of 81-ft. (24.68 m). For even more video distance, add a Tripp Lite DVI extender (such as B120-000; sold separately) to the connection. Ready to Use Right Out of the PackageThe plug-and-play splitter comes ready to connect right out of the package and requires no additional software or drivers. Its durable metal housing is designed to last a long time and fit seamlessly into any home or office application. Hardware is included for mounting the unit to a wall, on a pole, or in an EIA-standard 19-inch rack. TAA-Compliant for GSA Schedule PurchasesThe B116-004A is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. 1/4 System Requirements ● Source device with DVI-D or DVI-I video and 3.5 mm audio output ● Display device(s) with DVI-D or DVI-I video and 3.5 mm audio input Package Includes ● B116-004A 4-Port DVI Splitter with Audio and Signal Booster ● External power supply w/NEMA 1-15P plug & 5-ft. (1.52 m) cord (Input: 100-240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332156754 Product Type Signal Booster Technology DVI; Stereo Audio Host Connector DVI-I (FEMALE) VIDEO Max Supported Video Resolution 1920 x 1200 @ 60Hz Max 720P Range (ft) 80 Max 1080P Range (ft) 65 Max 1920 x 1200 Range (ft) 65 INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Product Length (in.) 7.87 Product Length (ft.) 0.66 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power), Green (Signal/Connection) PHYSICAL Color Black Included Mounting Accessories Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Rackmountable Yes Shipping Dimensions (hwd / in.) 2.00 x 4.40 x 12.20 Shipping Dimensions (hwd / cm) 5.08 x 11.18 x 30.99 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 Unit Dimensions (hwd / in.) 1.700 x 7.900 x 3.200 Unit Dimensions (hwd / cm) 4.3 x 20.1 x 8.1 Unit Packaging Type Box Unit Weight (lbs.) 1.2 Unit Weight (kg) 0.54 ENVIRONMENTAL Operating Temperature Range 32º to 104º F (0° to 40°C) Storage Temperature Range -4º to 140º F (-20° to 60° C) Operating Humidity Range 20 to 90% Storage Humidity Range 20 to 90% COMMUNICATIONS Max 1024 x 768 Range (ft) 80 Max 480P Range (ft) 80 Max 1440 x 900 Range (ft) 80 Max 1080i Range (ft) 65 Max 480i Range (ft) 80 Max 640 x 480 Range (ft) 80 Max 800 x 600 Range (ft) 80 Max 1600 x 1200 Range (ft) 80 CONNECTIONS Number of Ports 4 Side A - Connector 1 DVI-I (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (4) DVI-I (FEMALE) Side B - Connector 2 (4) 3.5MM (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.1 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE External Power Supply Certifications C-Tick; CCC; CE; FCC; GS; PSE; RoHS; TUV; UL; cUL Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B116-004A 价格&库存
很抱歉,暂时无法提供与“B116-004A”相匹配的价格&库存,您可以联系我们找货
