1000 Eaton Boulevard
Cleveland, OH 44122
United States
For longer extension distances, use a B126-1A0 or B126-1A0-WP-1 active receiver to:
● Extend a 1080p (60Hz) signal up to 150 ft. (45.7 m)
Extend a 1080i (60Hz) signal up to 200 ft. (61 m)
Extend a 3D signal up to 125 ft. (38.1 m)
For shorter distances, use a B126-1P0 passive receiver to:
● Extend a 1080p (60Hz) signal up to 50 ft. (15.2 m)
Highlights
Perfect for digital signs, trade
shows and retail settings
Supports high-definition video
resolutions up to 1080p (60 Hz)
Supports stereo and 7.1channel surround sound audio
Works with all operating
systems and HDMI video
sources
Plug and play—no software or
drivers to install
Extend a 1080i (60Hz) signal up to 100 ft. (30.5 m)
Further extend the signal range or add more displays by using a Tripp Lite B126-110 Remote
Repeater unit to:
● Add up to three repeaters on each channel of the B126-002 for a total of 4 displays per channel (a
receiver should be the last unit in a channel)
Extend a 1080p (60Hz) signal up to 125 ft. (38.1 m) for each repeater added into a channel
Extend a 1080i (60Hz) signal up to 175 ft. (53.3 m) for each repeater added into a channel
Extend a 3D signal up to 100 ft. (30.5 m) for each repeater added into a channel
2-Port HDMI over Cat5/6 Extender/Splitter, BoxStyle Transmitter, Video/Audio, 1080/60p up to
150ft, Intl Power Supply
MODEL NUMBER: B126-002-INT
Works with Tripp Lite’s B126-Series receivers to split a single HDMI signal into two separate signals, each
on a single Cat5e/6 cable, to two projectors, monitors or televisions up to 200 ft. (61 m) away.
Description
The B126-002-INT 2-Port HDMI over Cat5/Cat6 Extender/Splitter works with Tripp Lite B126-Series
remote receivers to split a single HDMI audio/video signal into two separate signals. It’s ideal for digital
signs, trade shows, presentations, retail settings and other applications where the video source is located
farther than conventional cables allow or that require multiple displays connected to one source. It uses
HDMI cable (see Tripp Lite’s P568-Series) to connect to the source and Cat5e/6 cable to transmit to the
remote monitors (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite’s N202-
1/4
Package Includes
External power supply w/CEE
7/16 Schuko, BS1363 UK and
AS2112 Australia plugs (Input:
100–240V, 50/60 Hz, 0.5A;
Output: 5V, 2A)
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Series).
When used with Tripp Lite’s B126-1A0 or B126-1A0-WP-1 active remote receivers, the Extender/Splitter
can extend a 1080i (60 Hz) signal up to 200 feet (61 m), a 1080p signal (60 Hz) up to 150 feet (45.7 m)
and a 3D signal up to 125 feet (38.1 m). With a B126-1P0 or B126-1P0-WP-1 passive remote receiver, it
can extend a 1080i (60 Hz) signal up to 100 feet (30.5 m) and a 1080p (60 Hz) signal up to 50 feet (15.2
m). Add up to three B126-110 remote repeaters to each channel to fully extend the signal range or add
more displays.
In addition to high-definition video, the B126-002-INT delivers full, rich stereo and 7.1-channel surround
sound (multi-channel or PCM) audio. Easy to set up with no software or drivers to install. Mounts to a wall,
rack or pole using the included hardware.
Features
Extends High-Definition Signals
● Extends a 1080i (60 Hz) signal up to 175 ft. (53.3 m), a 1080p (60 Hz) signal up to 125 ft. (38.1 m) and
a 3D signal up to 100 ft. (30.5 m) with each optional Tripp Lite B126-110 remote repeater
Extends a 1080i (60 Hz) signal up to 200 ft. (61 m), a 1080p (60 Hz) signal up to 150 ft. (45.7 m) and a
3D signal up to 125 ft. (38.1 m) with Tripp Lite B126-1A0 or B126-1A0-WP-1 active remote receiver
Extends a 1080i (60 Hz) signal up to 100 ft. (30.5 m) and a 1080p (60 Hz) signal up to 50 ft. (15.2 m)
with Tripp Lite B126-1P0 or B126-1P0-WP-1 passive remote receiver
Add up to 3 remote repeaters on each channel for maximum signal range
Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire
Cat5e/6 cable, such as Tripp Lite’s N202-Series)
Supports the Latest Video and Audio Resolutions
● Works with all operating systems and HDMI video sources
Supports HD resolutions up to 1080p (60 Hz)
Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio
Supports 24-bit True Color (8 bits per channel) and HDCP
Easy to Set Up and Use
● Plug-and-play engineering—no software or drivers to download and install
Connects quickly to source with HDMI cable, such as Tripp Lite’s P568-Series
LEDs indicate at a glance when the unit is receiving power and an HDMI signal from the source
Included mounting hardware lets you install the unit on a wall, rack or pole
International power supply with CEE 7/16 Schuko, BS1363 UK and AS2112 Australia plugs
Specifications
OVERVIEW
UPC Code
037332192783
Product Type
Cat5/Cat6 Transmitter
Technology
HDMI
2/4
Cleveland, OH 44122
United States
VIDEO
Max 720P Range (ft)
200
Max 1080P Range (ft)
150
Maximum Signal Range (ft)
150
Maximum Signal Range (m)
46
PHYSICAL
Color
Black
Included Mounting Accessories
Yes
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 5.00
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 12.70
Shipping Weight (lbs.)
1.41
Shipping Weight (kg)
0.64
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.54 x 6.35 x 9.14
ENVIRONMENTAL
Operating Temperature Range
0 to 40 C (32 to 104 F)
Storage Temperature Range
-20 to 60 C (-4 to 140 F)
Relative Humidity
20 to 90%
COMMUNICATIONS
Max 1024 x 768 Range (ft)
200
Max 480P Range (ft)
200
Max 1440 x 900 Range (ft)
200
Max 1080i Range (ft)
200
Max 480i Range (ft)
200
Max 640 x 480 Range (ft)
200
Max 800 x 600 Range (ft)
200
Max 1600 x 1200 Range (ft)
200
CONNECTIONS
Number of Ports
2
Side A - Connector 1
HDMI (FEMALE)
Side A - Connector 2
3.5MM (FEMALE)
Side B - Connector 1
(2) RJ45 (FEMALE)
3/4
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B126-002-INT”相匹配的价格&库存,您可以联系我们找货
