1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI over Cat5/6 Extender, Wall Plate Remote
Receiver for Video/Audio, Up to 150 ft. (45 m),
TAA
MODEL NUMBER: B126-1A0-WP-1
Highlights
Supports high-definition video
resolutions up to 1080p (60 Hz)
Supports stereo and 7.1channel surround sound audio
Works with all operating
systems and HDMI video
sources
Plug and play—no software or
drivers to install
Built-in equalization control lets
you adjust monitor image
System Requirements
Package Includes
Works with Tripp Lite’s B126-Series transmitters to extend an HDMI signal via Cat5e/6 cable to a
projector, monitor or television. Ideal for digital signs, schools and trade show presentations.
B126-1A0-WP-1 HDMI over
Cat5/Cat6 Active Remote
Receiver
Screwdriver for adjusting
equalization
External Power Supply with
NEMA 1-15P Plug(Input: 100240V, 50/60 Hz, 0.5A; Output:
5V, 2A, 5-ft. (1.52 m)
Mounting hardware
Owner's Manual
Description
The B126-1A0-WP-1 HDMI over Cat5/Cat6 Active Remote Receiver works with Tripp Lite's B126-002 or
B126-004 transmitter to extend an HDMI signal to a projector, monitor or television. It's ideal for digital
signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the
video source is located farther than conventional cables allow or that require multiple displays connected
to one source.
The receiver uses HDMI cable (see Tripp Lite's P568-Series) to connect to the monitor and Cat5e/6 cable
to receive the signal from the transmitter or a remote repeater in the chain (for best results, use 24 AWG
solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). No 110 punchdown connection is required.
The B126-1A0-WP-1 can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up
to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). You can connect up to three B126-110 remote
repeaters in the chain for a total of four HDMI displays and full signal extension of 700-ft. (213.36 m)
(1080i), 500-ft. (152.4 m) (1080p) or 400-ft. (121.92 m) (3D).
In addition to crystal-clear video, the B126-1A0-WP-1 delivers full, rich stereo and 7.1-channel surround
sound (multi-channel or PCM) audio when paired with a B126-002 or B126-004 transmitter. Built-in
equalization control lets you fine-tune the image quality at each remote display. Supports 24-bit True
Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install.
Mounts to a wall using the included hardware.
Features
Extends High-Definition Signals
● Works in tandem with Tripp Lite's B126-002 or B126-004 transmitter unit
Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m)
Connect up to 3 B126-110 remote repeaters to the chain for maximum signal range of 700-ft. (213.36
m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D)
Connects to previous link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire
No 110 punchdown connection required
1/5
Cleveland, OH 44122
United States
Supports the Latest Video and Audio Resolutions
● Works with all operating systems and HDMI video sources
Supports HD resolutions up to 1080p (60 Hz)
Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with a
Supports 24-bit True Color (8 bits per channel) and HDCP
Built-in equalization control lets you adjust the image on the local monitor
Easy to Set Up and Use
● Plug-and-play engineering—no software or drivers to download and install
Connects quickly to local monitor with HDMI cable, such as Tripp Lite's P568-Series
LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the
chain
Included mounting hardware lets you install the unit on a wall
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332162830
Product Type
Receiver
Technology
HDMI; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 1280 x 720 (720p) Range (ft)
150
Max 1920 x 1080 (1080p) Range (ft)
150
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Recommended Cabling
N202-Series Cat6 Patch Cable
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
150
Maximum Signal Range (m)
46
Maximum Signal Range Details
200 ft @ 1080i150 ft @ 1080p
2/5
Cleveland, OH 44122
United States
AUDIO
Audio Output
HDMI
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.37
AC Plug Type
NEMA 1-15P
Power Source
Receiver end only (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Power), Orange (Activity)
PHYSICAL
Color
Black
Material of Construction
Steel
Number of Displays
1
Form Factor/Mounting Options
Wallplate
Rackmountable
No
Shipping Dimensions (hwd / in.)
2.20 x 6.30 x 7.20
Shipping Dimensions (hwd / cm)
5.59 x 16.00 x 18.29
Shipping Weight (lbs.)
0.70
Shipping Weight (kg)
0.32
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
3/5
Cleveland, OH 44122
United States
Unit Dimensions (hwd / cm)
4 x 11.5 x 7
Unit Packaging Type
Box
Unit Weight (lbs.)
0.26
Unit Weight (kg)
0.12
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Signal Range (ft.)
200
Signal Range (m)
61
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
Recommended Category Cable
Cat5/Cat5e/Cat6 Cables
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV;RoHS; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
4/5
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B126-1A0-WP-1”相匹配的价格&库存,您可以联系我们找货
