B126-1A1-U-MCRO
B126-1A1-U-MCRO
    TRIPPLITE
    MICRO-HDMI EXTDR CAT5/6 125FT
B126-1A1-U-MCRO 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Micro-HDMI to HDMI over Cat5/Cat6 Active Extender Kit, 1080p 60 Hz, USB Powered, Up to 125 ft. (38 m), TAA Highlights ● Supports high-definition video resolutions up to 1080p (@ 60 Hz) ● Supports stereo audio and HDCP ● Works with all operating systems and HDMI sources ● Plug and play—no software, drivers or external power supply ● Built-in equalization control lets you adjust monitor image MODEL NUMBER: B126-1A1-U-MCRO System Requirements ● Laptop, Ultrabook™, tablet or other source with Micro-HDMI port ● Display with HDMI port Package Includes Transmitter and receiver work in tandem to extend an HDMI audio/video signal via Cat5e/6 cable from a Micro-HDMI source to an HDMI display up to 125 ft. Ideal for digital signs, schools and trade show presentations. Description The B126-1A1-U-MCRO Micro-HDMI to HDMI over Cat5/Cat6 Active Extender Kit includes a transmitter unit and a receiver unit that work in tandem to extend an HDMI audio/video signal from a Micro-HDMI source to an HDMI projector, monitor or television. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. The transmitter's built-in Micro-HDMI cable connects to the audio/video source, and the receiver's built-in HDMI cable connects to the display. Cat5e/6 cable connects the two units (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). Each unit is powered by an included USB Micro-B to USB-A cable, which must be connected between the unit and a USB port on the source, display or USB wall charger. You can also connect an optional HDMI monitor to the transmitter's local port with a user-supplied HDMI cable, such as Tripp Lite's P568-Series. The B126-1A1-U-MCRO can extend a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m) with full, rich stereo. Built-in RJ45 LEDs indicate the units are receiving power and a signal from the source. Built-in equalization control lets you fine-tune the image quality at each remote display. Easy to set up with no software or drivers to install. Works with all operating systems and HDMI sources. Features Extends HDMI Audio/Video Signals to an HDMI Display ● Extends a 1080p (@ 60 Hz) signal up to 125-ft. (38.1 m) ● Ideal for digital signs, trade shows, presentations, classrooms, churches and retail settings ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● Supports stereo audio and HDCP ● Built-in equalization control lets you adjust the image on the remote display Easy to Set Up and Use ● Plug-and-play engineering—no software, drivers or external power supply 1/5 ● Transmitter unit ● Receiver unit ● (2) USB Micro-B to USB-A cables, 3-ft. (0.91 m) ● Screwdriver for adjusting equalization ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Powered via included USB cables ● Units connect quickly to source and display with built-in cables ● Optional local HDMI monitor connects to transmitter with user-supplied HDMI cable ● LEDs indicate when units are receiving power and a signal from the source ● Works with all operating systems and HDMI sources TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332191502 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 125 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Transmitter Video Input Micro-HDMI Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Signal Range (m) 38 AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type USB Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Green (Power), Orange (Activity) PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 0.9 x 2.4 x 2 Receiver Unit Weight (lbs.) 0.15 Shipping Dimensions (hwd / in.) 7.87 x 5.59 x 1.73 Shipping Dimensions (hwd / cm) 19.99 x 14.20 x 4.39 Shipping Weight (lbs.) 0.49 Shipping Weight (kg) 0.22 Transmitter Unit Dimensions (hwd / in.) 0.9 x 2.4 x 2 Transmitter Unit Weight (lbs.) 0.15 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 125 Max 480P Range (ft) 125 Max 1440 x 900 Range (ft) 125 Max 1080i Range (ft) 125 Max 480i Range (ft) 125 Max 640 x 480 Range (ft) 125 Max 800 x 600 Range (ft) 125 Max 1600 x 1200 Range (ft) 125 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 MICRO HDMI (MALE) Side A - Connector 2 RJ45 (FEMALE); HDMI (FEMALE) Side A - Connector 3 MICRO-USB B (FEMALE) Side B - Connector 1 HDMI (MALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 MICRO-USB B (FEMALE) Connector Plating Gold FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-1A1-U-MCRO 价格&库存
很抱歉,暂时无法提供与“B126-1A1-U-MCRO”相匹配的价格&库存,您可以联系我们找货
