1000 Eaton Boulevard
Cleveland, OH 44122
United States
1-Port Plug-and-Play USB 2.0 over Cat5/Cat6
Extender Kit, Transmitter & Receiver, USB up to
164.04 ft. (50M), TAA
MODEL NUMBER: B203-101-PNP
Highlights
Extends USB data transfer up to
164 ft. over Cat5/Cat6 cable
Includes a transmitter with USB
cable and a 1-port receiver
Supports data transfer rates up
to 480 Mbps
Plug-and-play functionality; no
software or drivers required
Works with Windows®, Mac®
and Chromebook™ computers
System Requirements
USB-equipped Windows, Mac or
Chromebook computer
Cat5/Cat6 cable
Available AC outlet in receiver
location
Package Includes
Send data from a USB-equipped computer to a USB 2.0 peripheral up to 164 ft. away over user-supplied
Cat5/Cat6 cable. No software or drivers are required. Kit is useful for devices or areas that lack network
conductivity.
B203-101-PNP local transmitter
with built-in USB cable
B203-101-PNP 1-port remote
receiver
External Power Supply with
NEMA 1-15P Plug for receiver
(Input: 100-240V, 50/60 Hz,
0.5A; Output: 5V, 2A, 4.5-ft.
(1.37 m)
Owner's Manual
Description
Tripp Lite's B203-101-PNP 1-Port Plug-and-Play USB 2.0 over Cat5/Cat6 Extender Kit transmits data from
your computer to a USB 2.0 peripheral up to 164 ft. (50 m) away. It has plug-and-play functionality,
meaning you don't have to install drivers or software. For added convenience, the transmitter has a built-in
USB-A cable for connection to your computer. The USB signals travel between the transmitter and
receiver units over user-supplied Cat5/Cat6 cable. It's a simple, cost-effective solution for connecting your
computer to a printer or other USB peripheral that lacks network connectivity and is farther than 16-ft.
(4.88 m) away from your computer, which is the distance limitation for USB cables. For example, you can
use the B203-101-PNP to connect an impact printer to a server in another room. This extender kit is also
convenient for making connections in areas without network availability.
By using Cat5/Cat6 cable to carry signals, the B203-101-PNP extends your installation farther than is
possible with standard USB cables. Plus, Cat5/Cat6 cabling is readily available at low cost. For maximum
signal integrity, use solid-conductor Cat5/Cat6 UTP cabling, such as Tripp Lite's N202-series. The B203101-PNP extender kit can achieve data transfer rates up to 480 Mbps. It's backward compatible with USB
1.1 peripherals, but at USB 1.1 speeds. The B203-101-PNP works with all major operating systems
(Windows and Mac). Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule
purchases.
Features
Long-Distance Data Transfer to 1 Device—Up to 164-ft. (50 m) from the Source
● Send data to a USB 2.0 device located up to 164-ft. (50 m) from the source
USB signals travel over a single user-supplied Cat5/Cat6 cable
Includes transmitter with built-in USB-A cable and a 1-port receiver
Supports data transfer rates up to 480 Mbps
Greater Distance over Cat5/Cat6 Cable Provides Greater Flexibility
● Cat5/Cat6 cabling exceeds the 16-ft. (4.88 m) distance limitation of USB cables
Allows connection to devices that lack network connectivity in areas beyond the reach of standard USB
1/3
Cleveland, OH 44122
United States
cables
Makes connections in areas without network availability
Allows source to be in a secure location, separate from peripherals
Cat5/Cat6 cabling is cost-effective and readily available
For best results, use solid-conductor Cat5/Cat6 UTP cable, such as Tripp Lite's N202-series cable
Convenient Plug-and-Play Installation
● Plug-and-play functionality; no software or drivers required
Built-in 1-ft. (0.31 m) USB-A cable connects source and transmitter
User-supplied Cat5/Cat6 cable connects transmitter and receiver
Receiver unit has an external power supply
Widely Compatible
● Compatible with all major operating systems (Windows and Mac)
Backward compatible with USB 1.1 devices (at USB 1.1 speeds)
TAA-Compliant
● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332185211
Technology
USB 2.0 (High Speed)
VIDEO
HDR Support
No
POWER
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.
PHYSICAL
Color
Black
Material of Construction
PVC
Shipping Dimensions (hwd / in.)
2.20 x 7.20 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 18.29 x 16.51
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
2/3
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
-4 to 140 °F (-20 to 60 °C)
Relative Humidity
20 to 90% RH, Non-Condensing
COMMUNICATIONS
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
USB A (MALE)
Side A - Connector 2
RJ45 (FEMALE)
Side B - Connector 1
USB A (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 2.0 (up to 480 Mbps)
Recommended Category Cable
Cat6
STANDARDS & COMPLIANCE
Product Certifications
NOM (Mexico)
Product Compliance
RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia); REACH; WEEE; FCC (USA); Trade Agreements Act
(TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B203-101-PNP”相匹配的价格&库存,您可以联系我们找货
