CG5106-11983
CG5106-11983
    OPTION
    TELEMATICS CARD I/O EXPANDER
CG5106-11983 数据手册
Telematics card CONNECTING THINGS to the Cloud • Adds flexible I/O and connectivity for industrial telematics applications to CloudGate • Built in 3 axis accelerometer for movement detection and other applications • Dual SIM card reader for backup or roaming SIM • Built in microcontroller offloads all I/O from CloudGate Expand the functionality of CloudGate Te le m atics card Features Description Telematics base board (CG1106-11957) USB type A The Telematics Card allows the CloudGate Intelligent M2M Gateway to be used in advanced industrial telematics applications. The board can accept a range of Option or 3rd party developed I/O expanders that match the card and I/O connector to specific applications. The base card (CG1106) adds a 3 axis accelerometer with hardware motion detection, dual SIM slots for a backup or roaming SIM card as well as the primary SIM card, USB and USB on the go ports and a DTE DB9 serial port with power over serial support. The optional I/O expander piggy back board exposes a range of different I/O options including a second serial port, analog and digital inputs and digital outputs. Using different I/O expanders different levels of isolation and voltage ranges can be achieved. I/O Expander including CAN bus is also available. Other I/0 configurations including relays, isolated inputs, etc. can be developed on request. Get your application on the market faster with CloudGate! Also available Low cost serial card USB OTG microAB-type • Allows connection of USB 2.0 HS host and slave devices • Power switch and over-current protected 9 pin DB9 serial • RTS/CTS DSR/DTR flow control • DCD/RI available on some models of CloudGate (inquire for more details) • DTE interface • Supply voltage available via pin 9 (jumper selectable) 3 axis accelerometer 2 SIM sockets • Adds SIM backup/roaming SIM functionality to CloudGate Operating temperature • -30 to +70°C Humidity (operational) • 5 to 95% RH, non-condensing Storage temperature • -40 to +85°C Telematics card with I/O Expander (CG5106-11983) Telematics card with I/O Expander • ‘Molex type’ connector, 18 pin • 5 digital inputs (-/+ 32V) • 2 analog inputs (0V to 10V, 12 bits resolution) • 6 digital output (push-pull 0V to 3.3V OR open collector 0V to 30V/250mA@0.5V) • Auxiliary serial port (RX/TX/CTS/RTS, takes 2 digital inputs & 2 digital outputs) • 1-wire interface • 4 GND Other I/O Expander boards • Other I/O configurations including relays, isolated inputs, CAN bus, etc. on request. Telematics card with CAN I/O Expander (CG5106-11984) Industrial serial card Ethernet switch Telematics card with CAN bus & I/O Expander • ‘Molex type’ connector, 18 pin • 5 digital inputs (-/+32V) • 2 analog inputs (0V to 10V, 12 bits resolution) • 4 digital output (push-pull 0V to 3.3V OR open collector 0V to 30V/250mA@0.5V) • Auxiliary serial port (RX/TX/CTS/RTS, takes 2 digital inputs & 2 digital outputs) • 1-wire interface • 4 GND • CAN bus interface Other I/O Expander boards • Other I/O configurations including relays, isolated inputs, etc. on request. SDK + HDK CloudGate • ±2g/±4g/±8g, 3-Axis, 12-Bit Digital Accelerometer Developer card Breadboard card SDK + HDK *Specifications are subject to change. As part of the continual product improvement process, OPTION reserves the right to alter the specifications of this product. © 2014 OPTION. Option and the Option logo are registered trademarks of OPTION. All third-party trademarks are the property of the respective owners. Option nv - Gaston Geenslaan 14 - 3001 Leuven Belgium - T +32 16 317 411 - F +32 16 207 164 - www.option.com 1. Design and develop powerful applications for industrial telematics solutions 2. Configuration and any custom middleware are automatically installed www.option.com 3. Device is ready to connect Things to the Cloud DataSheet_v1.4 WLAN expansion card • Allows connection of USB 2.0 HS host devices • Power switch and over-current protected
CG5106-11983 价格&库存
很抱歉,暂时无法提供与“CG5106-11983”相匹配的价格&库存,您可以联系我们找货
CG5106-11983
