B126-002
B126-002
    TRIPPLITE
    HDMIEXTDR/SPLITTER2-PORT150FT
B126-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States For longer extension distances, use a B126-1A0 or B126-1A0-WP-1 active receiver to: Extend a 1080p (60Hz) signal up to 150 ft.Extend a 1080i (60Hz) signal up to 200 ft.Extend a 3D signal up to 125 ft. For Highlights ● Perfect for digital signs, trade shows and retail settings ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install shorter distances, use a B126-1P0 passive receiver to: Extend a 1080p (60Hz) signal up to 50 ft.Extend a 1080i (60Hz) signal up to 100 ft. Further extend the signal range or add more displays by using a Tripp Lite B126-110 Remote Repeater unit to: Add up to three repeaters on each channel of the B126-002 for a total of 4 displays per channel (a receiver should be the last unit in a channel)Extend a 1080p (60Hz) signal up to 125 ft. for each repeater added into a channelExtend a 1080i (60Hz) signal up to 175 ft. for each repeater added into a channelExtend a 3D signal up to 100 ft. for each repeater added into a channel 2-Port HDMI over Cat5/6 Extender/Splitter, BoxStyle Transmitter for Video/Audio, Up to 150 ft. (45 m), TAA System Requirements ● MODEL NUMBER: B126-002 For international use, a power supply with the appropriate plug type must be purchased separately. Package Includes Works with Tripp Lite’s B126-Series receivers to split a single HDMI signal into two separate signals, each on a single Cat5e/6 cable, to two projectors, monitors or televisions up to 150 ft. away. Description The B126-002 2-Port HDMI over Cat5/Cat6 Extender/Splitter works with Tripp Lite B126-Series remote receivers to split a single HDMI audio/video signal into two separate signals. It's ideal for digital signs, trade shows, presentations, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. It uses HDMI cable (see Tripp Lite's P568-Series) to connect to the source and Cat5e/6 cable to transmit to the remote monitors (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). When used with Tripp Lite's B126-1A0 or B126-1A0-WP-1 active remote receivers, the Extender/Splitter can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p signal (60 Hz) up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). With a B126-1P0 or B126-1P0-WP-1 passive remote receiver, it can extend a 1080i (60 Hz) signal up to 100-ft. (30.5 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m) Add up to three B126-110 remote repeaters to each channel to fully extend the signal range or add more displays. In addition to crystal-clear video, the B126-002 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals 1/5 ● B126-002 2-Port HDMI over Cat5/Cat6 Extender/Splitter ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m)) ● Mounting hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Extends a 1080i (60 Hz) signal up to 175-ft. (53.34 m), a 1080p (60 Hz) signal up to 125-ft. (38.1 m) and a 3D signal up to 100-ft. (30.5 m) with each optional Tripp Lite B126-110 remote repeater ● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m) with Tripp Lite B126-1A0 or B126-1A0-WP-1 active remote receiver ● Extends a 1080i (60 Hz) signal up to 100-ft. (30.5 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m) with Tripp Lite B126-1P0 or B126-1P0-WP-1 passive remote receiver ● Add up to 3 remote repeaters on each channel for maximum signal range ● Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to source with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and an HDMI signal from the source ● Included mounting hardware lets you install the unit on a wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332157508 Product Type Transceiver Technology HDMI; Cat5/5e; Cat6 Host Connector HDMI (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 200 ft @ 1080i150 ft @ 1080p AUDIO Audio Input 3.5mm Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Transmitter end only (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) PHYSICAL Color Black 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Shipping Dimensions (hwd / in.) 2.00 x 7.00 x 6.40 Shipping Dimensions (hwd / cm) 5.08 x 17.78 x 16.26 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.54 x 6.35 x 9.14 Unit Packaging Type Box Unit Weight (lbs.) 0.19 Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Signal Range (ft.) 200 Signal Range (m) 61 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 3.5MM (FEMALE) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; TUV; PSE; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-002 价格&库存
很抱歉,暂时无法提供与“B126-002”相匹配的价格&库存,您可以联系我们找货
