B126-2X2
B126-2X2
    TRIPPLITE
    HDMIMATRIXSWITCH2X2175FT
B126-2X2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2 x 2 HDMI over Cat5/6 Matrix Splitter Switch, Box-Style Transmitter for Video/Audio, Up to 125 ft. (38 m), TAA Highlights ● Routes any source to any display or same source to multiple displays ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Switches inputs via button, remote control or RS-232 serial ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install MODEL NUMBER: B126-2X2 System Requirements Package Includes Works with Tripp Lite’s 126-Series receivers to share multiple HDMI sources between multiple monitors, each on a single Cat5e/6 cable, up to 175 ft. away. Ideal for digital signs, trade shows, retail and presentations. ● B126-2X2 2 x 2 HDMI over Cat5/Cat6 Matrix Splitter Switch ● 3.5 mm to DB9 adapter cable (serial) ● Remote control ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.5A; Output: 5V, 2A, 4.5 ft. (1.37 m) ● Mounting hardware ● Owner's Manual Description The B126-2X2 2-port HDMI over Cat5/Cat6 Matrix Splitter Switch works with Tripp Lite remote receivers to share one or more HDMI sources between multiple projectors, monitors or televisions. It's ideal for digital signs, trade shows, presentations, retail and other applications where the video sources are located farther than conventional cables allow or that require multiple displays connected to one source. It uses HDMI cable (see Tripp Lite's P568-Series) to connect to the sources and Cat5e/6 cable to transmit to the remote monitors (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202Series). Any video source can be routed to any monitor, or you can send the same source to multiple monitors. Switch between inputs via pushbuttons, RS-232 serial or the included remote control. When used with Tripp Lite's B126-1A0 or B126-1A0-WP-1 active remote receivers, the switch can extend a 1080i (60 Hz) signal up to 175-ft. (53.34 m) or a 1080p signal (60 Hz) up to 125-ft. (38.1 m). With a B126-1P0 or B126-1P0-WP-1 passive remote receiver, it can extend a 1080i (60 Hz) signal up to 75-ft. (22.86 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m) Add up to three B126-110 remote repeaters to each channel to fully extend the signal range or add more displays. In addition to crystal-clear video, the B126-2X2 delivers full, rich stereo. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 175-ft. (53.34 m) and a 1080p (60 Hz) signal up to 125-ft. (38.1 m) with each optional B126-110 remote repeater ● Extends a 1080i (60 Hz) signal up to 175-ft. (53.34 m) and a 1080p (60 Hz) signal up to 125-ft. (38.1 m) with B126-1A0 or B126-1A0-WP-1 active remote receiver ● Extends a 1080i (60 Hz) signal up to 75-ft. (22.86 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m) with B126-1P0 or B126-1P0-WP-1 passive remote receiver ● Add up to 3 remote repeaters on each channel for maximum signal range ● Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo audio ● Supports 24-bit True Color (8 bits per channel) and HDCP Easy to Set Up and Use ● Route any video display to any monitor, or route the same display to multiple monitors ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to sources with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and an HDMI signal from the source ● Included mounting hardware lets you install the units on a wall, rack or pole TAA-Complian ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180209 Product Type Transceiver Technology HDMI; IR; Cat5/5e; Cat6 Host Connector (2) HDMI (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 175 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 AUDIO Audio Input HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Input Specs (V / Hz / A) 100-240V / 50-60Hz / 0.5A External Power Supply Output Specs (V / A) 5V/2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Source A, B (Orange), Output 1, 2 (Green); RJ45: Green (Connection), Orange (Activity) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.00 x 6.20 x 10.20 Shipping Dimensions (hwd / cm) 5.08 x 15.75 x 25.91 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 1.90 Shipping Weight (kg) 0.86 Unit Dimensions (hwd / in.) 1.200 x 5.000 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 12.7 x 9.91 Unit Packaging Type Box Unit Weight (lbs.) 0.43 Unit Weight (kg) 0.20 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 32 to 104 °F (0 to 40 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 175 Max 480P Range (ft) 175 Max 1440 x 900 Range (ft) 175 Max 1080i Range (ft) 175 Max 480i Range (ft) 175 Max 640 x 480 Range (ft) 175 Max 800 x 600 Range (ft) 175 Max 1600 x 1200 Range (ft) 175 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HDMI (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; RoHS; UL; cUL Product Compliance RoHS; REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-2X2 价格&库存
很抱歉,暂时无法提供与“B126-2X2”相匹配的价格&库存,您可以联系我们找货
