1000 Eaton Boulevard
Cleveland, OH 44122
United States
A computer with a DisplayPort v1.2 compatible Graphics Card (e.g. AMD Radeon with AMD Eyefinity
Highlights
technology) is required to display in video wall mode. Backward compatible with most DisplayPort 1.1a
Compliant with DisplayPort 1.2
equipment running current graphics drivers, with the feature set being limited to that of your equipment
Display the same image on
each monitor, extend the
desktop across them, or display
in video wall mode where
monitors are combined to
display as one
Supports computer video
resolutions up to 1920 x 1200,
and HD resolutions up to 1080p
Allows for video resolutions up
to 1920 x 2400 (1x2) and 3840 x
1200 (2x1) when in video wall
mode
(e.g. you may be limited to displaying in Clone / Mirror mode only). Compatibility with older graphics cards
is not guaranteed. MST compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps
amongst all monitors, with higher resolution monitors using up more bandwidth. 1080p monitors will use
up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be
different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display
settings interface for your graphics card. If the total percentage of bandwidth taken up by all of the
connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported
video resolutions and number of monitors will be dependent upon your graphics card. Check the
specifications of your graphics card to determine its capabilities.
2-Port DisplayPort to DVI Multi-Monitor Splitter,
MST Hub, 3840 x 1200 @ 60Hz, DP1.2, TAA
System Requirements
Eyefinity technology) is required
Mac OS X does not support
MST for NVIDIA and Intel
Graphics Processor Units,
limiting video display on the
connected monitors to mirror
mode.
DisplayPort 1.1a equipment
to that of your equipment (e.g.
in Clone / Mirror Mode only).
cards is not guaranteed.
Maximum supported video
capabilities.
A monitor with a DVI port.
MODEL NUMBER: B156-002-DVI
Ideal for digital signage at schools, airports and other public venues that require a DisplayPort video signal
to appear on two separate DVI monitors or expanded across both monitors as a video wall.
Description
Get everyone’s attention by broadcasting awesome messages in high definition video! With Tripp Lite's
B156-002-DVI 2-Port DisplayPort 1.2 to DVI MST Hub, you can split or expand a single DisplayPort signal
into two separate signals and display them on two DVI monitors using standard DisplayPort (Tripp Lite
P580-Series or P583-Series) and DVI (Tripp Lite P560-Series) cables. You can display the same image
on each monitor, extend the desktop across them, or display in video wall mode where monitors are
combined to display as one, enlarged monitor. The B156-002-DVI supports HD video resolutions up to
1920 x 1200 / 1080p @ 60Hz, 48-bit Deep Color (16 bits per channel), and is compatible with HDCP,
EDID and DDC. When displaying in video wall mode, resolutions up to 1920 x 2400 (1x2) and 3840 x
1200 (2x1) are supported. It comes with an external power supply and brackets for wall-, rack- or polemounting. All mounting hardware is included. Compliant with the Federal Trade Agreements Act (TAA) for
GSA Schedule purchases.
Features
Splitting, Extending, Multi-Display
● Splits or expands a DisplayPort video signal on two DVI monitors
1/4
Package Includes
B156-002-DVI Multi-Monitor
Splitter, MST Hub
Mounting Hardware
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Cleveland, OH 44122
United States
Display the same image on each monitor, extend the desktop across them, or display in video wall
mode where monitors are combined to display as one, enlarged monitor
Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p
Allows for video resolutions up to 1920 x 2400 (1x2) and 3840 x 1200 (2x1) when in video wall mode
Video Standards and Protocols
● Supports up to 48-bit Deep Color (16 bits per channel)
Complies with HDCP, EDID and DDC
Compatible with DisplayPort 1.2
Compatible with Apple® Thunderbolt connectors
Installation
● Plug-and-play; no software or drivers required
Easy to install; connect the DisplayPort video source to the hub's input port, connect the external power
supply and finally connect the two DVI monitors to the output ports
Mounting Options
● Wall-, rack- or pole-mounting; all mounting hardware is included
TAA-Compliant for GSA Schedule Purchases
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332175885
Technology
DVI; DisplayPort
Host Connector
DISPLAYPORT (MALE)
VIDEO
Max Supported Video Resolution
3840 x 1200 @ 60Hz
Max Supported Color Depth
48-bit Deep Color
3D Video Supported
Yes
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
2/4
Cleveland, OH 44122
United States
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
4.1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) Orange (Monitor Signal); (x1) Green (Power)
PHYSICAL
Color
Black
Material of Construction
Metal
Rackmountable
No
Shipping Dimensions (hwd / in.)
7.20 x 6.50 x 2.20
Shipping Dimensions (hwd / cm)
18.29 x 16.51 x 5.59
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
1.100 x 4.530 x 2.460
Unit Dimensions (hwd / cm)
11.5 x 6.24 x 2.7
Unit Dimensions (hwd / mm)
115 x 62.4 x 27
Unit Packaging Type
Box
Unit Weight (lbs.)
0.86
Unit Weight (kg)
0.39
ENVIRONMENTAL
Operating Temperature Range
14 to 167 °F (-10 to 75 °C)
Storage Temperature Range
-4 to 176 °F (-20 to 80 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
14 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
Side A - Connector 1
DISPLAYPORT (FEMALE)
3/4
Cleveland, OH 44122
United States
Side B - Connector 1
(2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
Displayport Specification
1.2a
HDCP Specification
1.3
Driver Required
No
MST Support
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
