B126-1A1-WP
B126-1A1-WP
    TRIPPLITE
    HDMI EXTNDR WALLPLATE KIT 200FT
B126-1A1-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Active Extender Kit, Wall Plate Transmitter/Receiver for Video/Audio, Up to 150 ft. (45 m), TAA MODEL NUMBER: B126-1A1-WP Highlights ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install ● Built-in equalization control lets you fine-tune image quality System Requirements Package Includes ● Transmitter unit ● Receiver unit ● Screwdriver for adjusting equalization ● (2) External Power Supplies with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● Mounting hardware ● Owner’s Manual Transmitter and receiver work in tandem to extend an HDMI signal via Cat5e/6 cable to a projector, monitor or television. Ideal for digital signs, schools and trade show presentations. Description The B126-1A1-WP HDMI over Cat5/Cat6 Active Extender Kit includes a transmitter unit and a receiver unit that work in tandem to extend an HDMI signal to a projector, monitor or television. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. HDMI cable (see Tripp Lite's P568-Series) connects a monitor to the receiver and the video source to the transmitter. Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) connects the two units. No 110 punchdown connection is required. The B126-1A1-WP can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). You can also connect up to three B126-110 remote repeaters in the chain (using Cat5e/6 cable) for a total of five HDMI displays and full signal extension of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) or 400-ft. (121.92 m) (3D). In addition to crystal-clear video, the B126-1A1-WP delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio. Built-in equalization control lets you fine-tune the image quality at each remote display. Supports 24-bit True Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install. Mounts to a wall using the included hardware. Features Extends High-Definition Signals 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m) ● Connect up to 3 B126-110 remote repeaters to the chain for maximum signal range of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D) ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● No 110 punchdown connection required Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP ● Built-in equalization control lets you adjust the image on the local monitor Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Units connect quickly to source and display with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the chain ● Included mounting hardware lets you install the unit on a wall TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332168078 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Recommended Cabling Cat5/Cat5e/Cat6 Cables Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 AUDIO 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Specification 7.1 Channel Surround Sound (Multi-Channel or PCM) INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Input Specs (V / Hz / A) 100-240V / 50-60Hz / 0.5A External Power Supply Output Specs (V / A) 5V/2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity), Blue (Audio) PHYSICAL Color White Material of Construction Steel Number of Displays 1 Rackmountable No Receiver Unit Dimensions (hwd / cm.) 2.6 x 9.2 x 6.4 Receiver Unit Dimensions (hwd / in.) 1 x 3.6 x 2.5 Receiver Unit Weight (kg) 0.09 Receiver Unit Weight (lbs.) 0.2 Shipping Dimensions (hwd / in.) 0.25 x 5.00 x 10.60 Shipping Dimensions (hwd / cm) 0.64 x 12.70 x 26.92 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 Transmitter Unit Dimensions (hwd / cm.) 2.6 x 9.2 x 6.4 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Transmitter Unit Dimensions (hwd / in.) 1 x 3.6 x 2.5 Transmitter Unit Weight (kg) 0.09 Transmitter Unit Weight (lbs.) 0.2 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 14 to 167 F (-10 to 75 C) Storage Temperature Range -4 to 176 F (-20 to 80 C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Signal Range (ft.) 200 Signal Range (m) 61 EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Side A - Connector 1 HDMI (FEMALE); RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE); RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; RoHS; UL; cUL WARRANTY & SUPPORT 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-1A1-WP 价格&库存
很抱歉,暂时无法提供与“B126-1A1-WP”相匹配的价格&库存,您可以联系我们找货
