B126-110
B126-110
    TRIPPLITE
    HDMIACTIVEEXTENDER175FT
B126-110 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Extender, Box-Style Remote Repeater for Video/Audio, Up to 125 ft. (38 m), TAA MODEL NUMBER: B126-110 Highlights ● Extends 1080i (60 Hz) signal up to 175-ft. (53.34 m) ● Connect up to 3 units in a chain for maximum extension ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Plug and play—no software or drivers to install System Requirements ● HDMI video source and displays Package Includes Works with Tripp Lite’s B126-Series transmitters and receivers to extend an HDMI signal via Cat5e/6 cable to multiple projectors, monitors or televisions in a chain. Ideal for digital signs and trade show presentations. Description The B126-110 HDMI over Cat5/Cat6 Active Remote Repeater works with Tripp Lite B126-Series transmitters and receivers to extend an HDMI signal to multiple projectors, monitors or televisions in a chain. It's ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. The repeater uses HDMI cable (see Tripp Lite's P568-Series) to connect to the local monitor and Cat5e/6 cable to transmit to the receiver and/or other remote repeaters in the chain (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). The B126-110 can extend a 1080i (60 Hz) signal up to 175-ft. (53.34 m), a 1080p (60 Hz) signal up to 125-ft. (38.1 m) and a 3D signal up to 100 feet. You can connect up to three B126-110 units in the chain for a total of four HDMI displays and full signal extension of 700 feet (1080i), 500 feet (1080p) or 400 feet (3D). In addition to crystal-clear video, the B126-110 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio when used with a B126-Series transmitter. Built-in equalization control lets you fine-tune the image quality at each remote display. Supports 24-bit True Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 175-ft. (53.34 m), a 1080p (60 Hz) signal up to 125-ft. (38.1 m) and a 3D signal up to 100-ft. (30.5 m) ● Connect up to 3 remote repeaters to the chain for maximum signal range of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D) ● Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) Supports the Latest Video and Audio Resolutions 1/5 ● B126-110 HDMI over Cat5/Cat6 Active Remote Repeater ● Screwdriver for adjusting equalization ● External Power Supply with NEMA 1-15P Plug(Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Mounting hardware ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with B126002 or B126-004 transmitter unit ● Supports 24-bit True Color (8 bits per channel) and HDCP ● Built-in equalization control lets you adjust the image on the local monitor Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to local monitor with HDMI cable, such as Tripp Lite's P568-Series ● Included mounting hardware lets you install the unit on a wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332168061 Product Type Transceiver Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max. Distance (Between any 2 Units) 125 ft Max Number of Ports (Entire Chain) 4 Max 720P Range (ft) 175 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-01  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.10 x 6.20 x 7.20 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 5.33 x 15.75 x 18.29 Shipping Weight (lbs.) 1.08 Shipping Weight (kg) 0.49 Unit Dimensions (hwd / in.) 1.100 x 4.500 x 2.500 Unit Dimensions (hwd / cm) 2.54 x 11.43 x 6.35 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 175 Max 480P Range (ft) 175 Max 1440 x 900 Range (ft) 175 Max 1080i Range (ft) 175 Max 480i Range (ft) 175 Max 640 x 480 Range (ft) 175 Max 800 x 600 Range (ft) 175 Max 1600 x 1200 Range (ft) 175 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PORT EXPANSION Daisy-chainable or Cascadable Daisychainable and Cascadeable FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/6 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV;RoHS; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-110 价格&库存
很抱歉,暂时无法提供与“B126-110”相匹配的价格&库存,您可以联系我们找货
