B126-1A1-INT
B126-1A1-INT
    TRIPPLITE
    HDMIEXTENDERKIT200FT
B126-1A1-INT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Active Extender Kit, Box-Style Transmitter/Receiver, Video/Audio, 1080p 60 Hz, Up to 150 ft. (45 m), Intl Power Supply MODEL NUMBER: B126-1A1-INT Highlights ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install ● Built-in equalization control lets you adjust monitor image Package Includes ● Transmitter unit ● Receiver unit ● Screwdriver for adjusting equalization ● (2) External power supplies w/CEE 7/16 Schuko, BS1363 UK and AS2112 Australia plugs (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) Transmitter and receiver work in tandem to extend an HDMI signal via Cat5e/6 cable to a projector, ● Mounting hardware monitor or television. Ideal for digital signs, schools and trade show presentations. ● Owner’s manual Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 200 ft. (61 m), a 1080p (60 Hz) signal up to 150 ft. (45.7 m) and a 3D signal up to 125 ft. (38.1 m) ● Connect up to 3 B126-110 remote repeaters between the transmitter and receiver for maximum signal range of 700 ft./213 m (1080i), 500 ft./152.4 m (1080p) and 400 ft./121.9 m (3D) ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP ● Built-in equalization control lets you adjust the image on the local monitor Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Works with all operating systems and HDMI video sources ● Units connect quickly to monitors with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the chain ● Included mounting hardware lets you install the units on a wall, rack or pole ● International power supplies with CEE 7/16 Schuko, BS1363 UK and AS2112 Australia plugs Specifications 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332192707 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Signal Range (ft) 200ft @ 1080i 150ft @ 1080p Signal Range (m) 61 45.7 Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 AUDIO Audio Input HDMI; 3.5mm Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Input Specs (V / Hz / A) 100-240V / 50-60Hz / 0.5A External Power Supply Output Specs (V / A) 5V/2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type AS/NZS 3112; BS1363; CEE 7/16 Schuko Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Green (Power), Orange (Activity) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Receiver Unit Dimensions (hwd / in.) 1 x 3.6 x 2.5 Receiver Unit Weight (lbs.) 0.2 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 5.00 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 12.70 Shipping Weight (lbs.) 2.56 Shipping Weight (kg) 1.16 Transmitter Unit Dimensions (hwd / in.) 1 x 3.6 x 2.5 Transmitter Unit Weight (lbs.) 0.2 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 200 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (2) HDMI (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 3.5MM (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV;RoHS; UL; cUL WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-1A1-INT 价格&库存
很抱歉,暂时无法提供与“B126-1A1-INT”相匹配的价格&库存,您可以联系我们找货
