B140-101X-U
B140-101X-U
    TRIPPLITE
    DVIEXTENDERCAT5/6125FT
B140-101X-U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/6 Active Extender Kit, Transmitter/Receiver for Video, DVI-D Single Link, Up to 125 ft. (38 m) Highlights ● Supports computer video resolutions up to 1920 x 1200 (60 Hz) ● Supports high-definition video resolutions up to 1080p ● USB Micro-B port supplies power to the receiver ● Works with all operating systems ● Plug and play—no software or drivers to install MODEL NUMBER: B140-101X-U System Requirements ● Computer with DVI output port and available USB port ● Display with DVI input port and available USB port Package Includes Transmitter and receiver work in tandem to extend a DVI-D signal via Cat5e/6 cable to a projector, monitor or television up to 125 ft. away. Ideal for digital signs, schools and trade show presentations. ● Transmitter unit ● Receiver unit ● Screwdriver for adjusting equalization ● USB Micro-B cable, 3-ft. (0.91 m) ● Owner's manual Description The B140-101X-U DVI over Cat5/6 Active Extender Kit includes a transmitter unit and a receiver unit that work in tandem to extend a DVI-D signal to a projector, monitor or television. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. Each unit features a built-in DVI cable for connecting to your computer's DVI output port and the display's DVI input port. Cat5e/6 cable connects the two units (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). An included USB Micro-B cable connects the receiver and a USB port on the display or a USB wall charger to supply power to the unit. The HDCP-compatible B140-101X-U can extend a 1920 x 1200 (60 Hz) signal, including 1080p, up to 125-ft. (38.1 m). LEDs on the RJ45 ports indicate when the units are receiving power and a DVI signal from the source. Built-in equalization control lets you fine-tune the image on the remote display. Easy to set up with no software or drivers to install. Compatible with all operating systems. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features Extends High-Definition DVI-D Single-Link Signals Up to 125-ft. (38.1 m) ● Ideal for digital signs, trade shows, presentations, classrooms, churches and retail settings ● Extends a 1920 x 1200 (60 Hz) signal, including 1080p, up to 125-ft. (38.1 m) ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● Supports HDCP ● Built-in equalization control lets you adjust the image on the remote display Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Included USB Micro-B cable provides power to receiver ● Works with all operating systems 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● LEDs indicate when the units are receiving power and sharing a signal ● Units connect quickly to source and display with built-in DVI connectors TAA Compliant ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332190239 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 175 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Transmitter Video Input DVI-D (Single Link) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-D (Single Link) Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 INPUT Bus Powered No POWER Power Source Type USB 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Source Receiver end only (Included) Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Power (Green); Activity (Orange) PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Receiver Unit Weight (lbs.) 0.14 Shipping Dimensions (hwd / in.) 7.87 x 5.59 x 1.73 Shipping Dimensions (hwd / cm) 19.99 x 14.20 x 4.39 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 Transmitter Unit Dimensions (hwd / in.) 1.36 x 0.94 x 14.16 Transmitter Unit Weight (lbs.) 0.07 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 175 Max 480P Range (ft) 175 Max 1440 x 900 Range (ft) 175 Max 1080i Range (ft) 125 Max 480i Range (ft) 175 Max 640 x 480 Range (ft) 175 Max 800 x 600 Range (ft) 175 Max 1600 x 1200 Range (ft) 175 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 MICRO-USB B (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-101X-U 价格&库存
很抱歉,暂时无法提供与“B140-101X-U”相匹配的价格&库存,您可以联系我们找货
