B140-101X
B140-101X
    TRIPPLITE
    DVI CAT5 EXTENDER KIT
B140-101X 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/6 Active Extender Kit, Box-Style Transmitter/Receiver for Video, Up to 200 ft. (60 m), TAA Highlights ● Extender kit comes with transmitter and receiver units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Can further expand the range and number of monitors by adding B140-110 repeaters ● Compatible with all operating systems ● Plug and play, no software or drivers required ● Features a built-in Equalization control for adjustment of the video image ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-101X Transmit a DVI-D Single-Link signal up to 200 ft. away using a single Cat5e/6 patch cable Description The B140-101X is a DVI Over Cat5 Active Extender Kit that comes with both transmitter and receiver units. It transmits a DVI-D Single-Link signal up to 200-ft. (60.96 m) away using a single Cat5e/6 patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp Lite's N202-Series). The B140-101X is compatible with all operating systems, and is plug and play, with no software or drivers required. It features a built-in Equalization control for adjustment of the video image. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Installation is simple. Connect a the built-in DVI connector on the transmitter unit to a DVI source. Connect the receiver unit to a display using a Tripp Lite P561-Series DVI cable (not included). Finally, the RJ45 ports on the transmitter and receiver units are connected using a single Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 150-ft. (45.72 m) from the source,, or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) Further expand the range and number of monitors by using a B140-110 repeater unit. Add up to four remote units (three repeaters and one active receiver) in a single chain, for a total of 4 displays. (An active receiver should be the last unit in a chain) A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the chain, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m) System Requirements Package Includes ● B140-101X local transmitter unit ● B140-101X remote receiver unit ● Screwdriver (used for Equalization control) ● Mounting hardware for receiver unit ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m) ● Owner's manual Features ● Extender kit comes with transmitter and receiver units ● Transmit a DVI-D Single-Link signal up to 200-ft. (60.96 m) away using a single Cat5e/6 patch cable ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Features a built-in Equalization control for adjustment of the video image ● Further expand the range and number of monitors by using a B140-110 repeater unit ● Add up to four remote units (three repeaters and one active receiver) in a single chain, for a total of 4 displays. (An active receiver should be the last unit in a channel) 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the chain, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m) ● HDCP compatible ● Compatible with all operating systems ● Plug and play; no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332154095 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-D (Single Link) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-D (Single Link) Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT Bus Powered No 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Receiver end only (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Power (Green); Activity (Orange) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-01  Form Factor/Mounting Options Pigtail; Box; Wall-mount Receiver Unit Dimensions (hwd / in.) 3.61 x 2.53 x 1.01 Receiver Unit Weight (lbs.) 0.4 Shipping Dimensions (hwd / in.) 2.00 x 6.20 x 8.30 Shipping Dimensions (hwd / cm) 5.08 x 15.75 x 21.08 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 Transmitter Unit Dimensions (hwd / in.) 1.36 x 0.94 x 14.16 Transmitter Unit Weight (lbs.) 0.14 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Housing Plastic; Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B140-101X 价格&库存
很抱歉,暂时无法提供与“B140-101X”相匹配的价格&库存,您可以联系我们找货
