1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA with Audio over Cat5/Cat6 Transmitter and
Receiver with Repeater Kit, Box-Style, 1920x1440
60 Hz, Up to 1000 ft. TAA
Highlights
Kit comes with both local
transmitter and remote/repeater
units
Locate multiple sets of monitors
and speakers at different points
in a chain of up to 2,000 ft. by
connecting additional receiver
(B132-100A or B132-100A-WP1) or repeater (B132-110A) units
Up to 4 remote units (3
repeaters and 1 receiver) can be
connected together, providing
audio/video to up to 4 sets of
monitors and speakers
24Awg, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N022-01K-GY (Cat5) and N22201K-GY (Cat6), is required to
achieve maximum distance and
resolution
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B130-111A
Features
Kit comes with both local transmitter and remote/repeater units.
Locate multiple sets of monitors and speakers at different points in a chain of up to 2,000 ft. by
connecting additional receiver (B132-100A or B132-100A-WP-1) or repeater (B132-110A) units.
Up to 4 remote units (3 repeaters and 1 receiver) can be connected together, providing audio/video to
up to 4 sets of monitors and speakers
24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6),
is required to achieve maximum distance and resolution
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
Extend a 1920 x 1440 (60Hz) video and audio signal up to 500 ft., or a 1024 x 768 (60Hz) video and
audio signal up to 1,000 ft., between the local transmitter and the first remote/repeater unit in the
installation.
Extend a 1920 x 1440 (60Hz) video and audio signal up to an additional 500 ft., or a 1024 x 768 (60Hz)
video and audio signal up to an additional 1,000 ft., from the first remote/repeater unit to the last set of
display and speakers in the installation.
Features built-in Equalization and Gain controls for video image adjustment.
Includes mounting hardware that allows wall mounting, rackmounting or pole mounting.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Specifications
OVERVIEW
1/3
System Requirements
Computer with VGA video and
3.5mm Audio outputs
Monitor / TV / Speakers with
VGA and 3.5mm Audio inputs
Package Includes
B130-111A local transmitter unit
B130-111A remote/repeater unit
(2) External Power Supplies with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; 5V, 2A, 5
ft.)
Screwdriver for video
adjustment
Mounting hardware
Owner's manual
Cleveland, OH 44122
United States
UPC Code
037332161628
Product Type
Extender Kit
Technology
VGA/SVGA; Stereo Audio; Cat5/5e; Cat6
VIDEO
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
INPUT
Bus Powered
No
POWER
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; 5V, 2A, 5 ft.
PHYSICAL
Color
Black
Number of Displays
1
Form Factor/Mounting Options
Box
Shipping Dimensions (hwd / in.)
2.00 x 6.30 x 8.40
Shipping Dimensions (hwd / cm)
5.08 x 16.00 x 21.34
Shipping Weight (lbs.)
2.00
Shipping Weight (kg)
0.91
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
2/3
Cleveland, OH 44122
United States
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
EDID Compatible
No
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
(2) HD15 (FEMALE)
Side A - Connector 2
RJ45 (FEMALE)
Side B - Connector 1
HD15 (FEMALE)
Side B - Connector 2
(2) RJ45 (FEMALE)
Side B - Connector 3
3.5MM (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B130-111A”相匹配的价格&库存,您可以联系我们找货
