B140-004
B140-004
    TRIPPLITE
    DVIEXTDR/SPLITTER4-PORT200FT
B140-004 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port DVI over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video, DVI-D Single Link, 200 ft. (60 m), TAA Highlights ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● For longer distances - Use a B140-1A0 active receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) ● For shorter distances - Use a B140-1P0 passive receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Can further expand the range and number of monitors by adding B140-110 repeaters ● Compatible with all operating systems ● Plug and play, no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-004 Transmit a DVI-D single-link signal to 4 monitors up to 200 ft. away using a single Cat5/6 Ethernet cable. Description The B140-004 transmits a DVI-D Single-Link signal to four monitors up to 200-ft. (60.96 m) away using a single Cat5e/6 patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp Lite's N202-Series). An additional DVI port is provided for the connection of a local monitor. This local DVI port can also be used to daisychain up to 3 units together, allowing for the connection of up to 13 monitors (12 remote, 1 local). Mounting hardware is included that allows the unit to be rackmounted, wallmounted or pole mounted. In addition, up to three units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB 19" rackmount bracket. The B140-004 is compatible with all operating systems, and is plug and play, with no software or drivers required. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Installation is simple. Connect the B140-004 transmitter to a DVI source using a Tripp Lite P561-Series DVI cable (not included). Connect a Tripp Lite B140-series receiver (not included) to each display using a Tripp Lite P561-Series DVI cable (not included). Finally, each remote receiver is connected to an RJ45 port on the B140-004 using a single Cat5e/6 cable. For longer extension distances, use a B140-1A0 active receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m). For shorter extension distances, use a B140-1P0 passive receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 50 ft., or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m). Further expand the range and number of monitors by using a B140-110 repeater unit. Add up to four remote units (three repeaters and one active receiver) to each channel of the B140-004, for a total of 4 displays per channel. (An active receiver should be the last unit in a channel) A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m) Features ● Transmit a DVI-D Single-Link signal to four monitors up to 200-ft. (60.96 m) away using a single Cat5e/6 patch cable ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● For longer distances - Use a B140-1A0 active receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 150-ft. (45.72 m), or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) ● For shorter distances - Use a B140-1P0 passive receiver unit to extend a 1920 x 1080 @ 60Hz signal up to 50 ft., or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) 1/5 System Requirements Package Includes ● B140-004 DVI Over Cat5 Extender/Splitter, 4-Port Local Transmitter Unit ● 1-ft. (0.31 m) DVI daisychain cable ● Mounting hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A Output: 5V, 2A) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● An additional DVI port is provided for the connection of a local monitor. This local DVI port can also be used to daisychain up to 3 units together, allowing for the connection of up to 13 monitors (12 remote, 1 local). ● Further expand the range and number of monitors by using a B140-110 repeater unit ● Add up to four remote units (three repeaters and one active receiver) to each channel of the B140-004, for a total of 4 displays per channel. (An active receiver should be the last unit in a channel) ● A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m) ● HDCP compatible ● Compatible with all operating systems ● Plug and play; no software or drivers required ● Mounting hardware is included that allows the unit to be rackmounted, wallmounted or pole mounted. In addition, up to three units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB 19" rackmount bracket. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332156693 Product Type Transceiver Technology DVI; Cat5/5e; Cat6 Host Connector DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-I Transmitter - Number of Video Outputs 4 Transmitter - Local Display Output DVI-I Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power); RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 4 Optional Mounting Accessory Notes Up to three transmitters local units can be mounted in 1U of rack space using a Tripp Lite  B132-004RB  Extender/Splitter 19in rackmount bracket Form Factor/Mounting Options Box; Wall-mount; Rackmount Shipping Dimensions (hwd / in.) 2.10 x 10.10 x 6.40 Shipping Dimensions (hwd / cm) 5.33 x 25.65 x 16.26 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.86 x 12.7 x 10.16 Unit Packaging Type Box Unit Weight (lbs.) 0.8 Unit Weight (kg) 0.36 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 4 Side A - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 DVI-I (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B140-004 价格&库存
很抱歉,暂时无法提供与“B140-004”相匹配的价格&库存,您可以联系我们找货
