1000 Eaton Boulevard
Cleveland, OH 44122
United States
DVI over Cat5/6 Extender, Box-Style Remote
Repeater for Video, DVI-I Dual Link, Up to 175 ft.
(53 m), TAA
Highlights
Insert into your Tripp Lite B140Series DVI over Cat5 installation
to expand the range and
number of monitors (Cannot be
used with Passive extender kits
or Passive receiver units)
Supports DVI-D Single-Link
video resolutions up to 1920 x
1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz
signal up to 125-ft. (38.1 m), or
a 1024 x 768 @ 60Hz signal up
to 175-ft. (53.34 m)
Use 24AWG, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N202-Series, to achieve
maximum distance and
resolution
Compatible with all operating
systems
Plug and play, no software or
drivers required
Features a built-in Equalization
control for adjustment of the
video image
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B140-110
Extend and expand a Tripp Lite B140-Series DVI over Cat5 installation
Description
The B140-110 remote repeater unit can be added to your Tripp Lite B140-Series HDMI over Cat5
installation to expand the range and number of monitors. It transmits a DVI-D Single-Link signal up to 175ft. (53.34 m) away using a single Cat5e/6 patch cable.To achieve maximum distance and resolution, use
24AWG Solid Wire Cat5e/6 cable (Tripp Lite's N202-Series). The B140-110 is compatible with all
operating systems, and is plug and play, with no software or drivers required. It features a built-in
Equalization control for adjustment of the video image. Compliant with the Federal Trade Agreements Act
(TAA) for GSA Schedule purchases.
Installation is simple; just insert the B140-110 repeater into the middle of your installation (Cannot be used
with Passive extender kits or Passive receiver units). In the case of a B140-101X active extender kit, the
built-in DVI connector on the transmitter is connected to the DVI source. It is then connected via Cat5e/6
cable to the B140-110, which is connected via Cat5e/6 cable to the B140-101X receiver unit. Finally, a
monitor is connected to both the repeater and receiver units using Tripp Lite P561-Series DVI cable (not
included).
● Connect up to four remote units (three repeaters and one active receiver) in a single chain, for a total of
4 displays. (An active receiver should be the last unit in a chain)
A 1920 x 1080 @ 60Hz signal can be extended up to 125-ft. (38.1 m) from each repeater to the next
unit in the channel, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m)
Features
Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz signal up to 125-ft. (38.1 m), or a 1024 x 768 @ 60Hz signal up to 175ft. (53.34 m)
Insert into your Tripp Lite B140-Series DVI over Cat5 installation to expand the range and number of
monitors (Cannot be used with Passive extender kits or Passive receiver units)
Add up to four remote units (three repeaters and one active receiver) in a single chain, for a total of 4
unit in the chain, or a 1024 x 768 @ 60Hz signal can be extended up to 175-ft. (53.34 m)
Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance
and resolution
1/4
System Requirements
Package Includes
B140-110 Extender / Repeater
Unit
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A)
Mounting Hardware
Screwdriver for Equalization
Adjustment
Cleveland, OH 44122
United States
Features a built-in Equalization control for adjustment of the video image
HDCP compatible
Compatible with all operating systems
Plug and play; no software or drivers required
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332168085
Product Type
Transceiver
Technology
DVI; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
175
Max 1080P Range (ft)
125
Max 1280 x 720 (720p) Range (ft)
125
Max 1920 x 1080 (1080p) Range (ft)
125
Receiver/Transceiver Video Output
DVI-I
Range Extension using other Tripp
Lite product
175ft
Recommended Cabling
N202-Series Cat6 Patch Cable
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
175
Maximum Signal Range (m)
53
Maximum Signal Range Details
175 ft @ 1024 x 768 XGA125 ft @ 1920 x 1080 UXGA
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
2/4
Cleveland, OH 44122
United States
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Power (Green); Activity (Orange)
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-01
Form Factor/Mounting Options
Box; Wall-mount
Shipping Dimensions (hwd / in.)
2.20 x 7.20 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 18.29 x 16.51
Shipping Weight (lbs.)
1.50
Shipping Weight (kg)
0.68
Unit Dimensions (hwd / in.)
1.100 x 4.500 x 2.500
Unit Dimensions (hwd / cm)
2.54 x 11.43 x 6.35
Unit Packaging Type
Box
Unit Weight (lbs.)
0.4
Unit Weight (kg)
0.18
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
175
3/4
Cleveland, OH 44122
United States
Max 480P Range (ft)
175
Max 1440 x 900 Range (ft)
175
Max 1080i Range (ft)
125
Max 480i Range (ft)
175
Max 640 x 480 Range (ft)
175
Max 800 x 600 Range (ft)
175
Max 1600 x 1200 Range (ft)
175
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK)
Side B - Connector 2
RJ45 (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B140-110”相匹配的价格&库存,您可以联系我们找货
