1000 Eaton Boulevard
Cleveland, OH 44122
United States
A computer with a DisplayPort v1.2 compatible Graphics Card (e.g. AMD Radeon with AMD Eyefinity
Highlights
technology) is required to display in video wall mode. Backward compatible with most DisplayPort 1.1a
Compliant with DisplayPort 1.2
equipment running current graphics drivers, with the feature set being limited to that of your equipment
Splits or expands a DisplayPort
audio/video signal on two HDMI
monitors
Display the same image on
each monitor, extend the
desktop across them, or display
in video wall mode where
monitors are combined to
display as one
Supports Ultra High Definition
(UHD) video resolutions up to
4K @ 30Hz (3840 x 2160) - see
System Requirements
Supports up to 48-bit Deep
Color (16 bits per channel)
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
(e.g. you may be limited to displaying in Clone / Mirror mode only). Compatibility with older graphics cards
is not guaranteed. MST compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps
amongst all monitors, with higher resolution monitors using up more bandwidth. 1080p monitors will use
up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be
different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display
settings interface for your graphics card. If the total percentage of bandwidth taken up by all of the
connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported
video resolutions and number of monitors will be dependent upon your graphics card. Check the
specifications of your graphics card to determine its capabilities.
2-Port DisplayPort to HDMI Multi-Monitor Splitter
MST Hub, 4K UHD, DP1.2, TAA
MODEL NUMBER: B156-002-HDMI
System Requirements
Eyefinity technology) is required
Mac OS X does not support
MST for NVIDIA and Intel
Graphics Processor Units,
limiting video display on the
connected monitors to mirror
mode.
DisplayPort 1.1a equipment
to that of your equipment (e.g.
in Clone / Mirror Mode only).
cards is not guaranteed.
Maximum supported video
capabilities.
A monitor with a HDMI port.
Ideal for digital signage at schools, airports and other public venues that require a DisplayPort video signal
to appear on two separate HDMI monitors or expanded across both monitors as a video wall.
Description
Get everyone’s attention by broadcasting awesome messages in ultra-high definition video! With Tripp
Lite's B156-002-HDMI 2-Port DisplayPort 1.2 to HDMI MST Hub, you can split or expand a single
DisplayPort signal into two separate signals and display them on two HDMI monitors using standard
DisplayPort (Tripp Lite P580-Series or P583-Series) and HDMI (Tripp Lite P568-Series) cables. You can
display the same image on each monitor, extend the desktop across them, or display in video wall mode
where monitors are combined to display as one, enlarged monitor. The B156-002-HDMI supports UltraHigh Definition (UHD) video resolutions up to 4K @ 30Hz (3840 x 2160), 48-bit Deep Color (16 bits per
channel), and is compatible with HDCP, EDID and DDC. It comes with an external power supply and
brackets for wall-, rack- or pole-mounting. All mounting hardware is included. Compliant with the Federal
Trade Agreements Act (TAA) for GSA Schedule purchases.
Package Includes
B156-002-HDMI DisplayPort 1.2
to HDMI Multi-Stream Transport
(MST) Hub
Mounting Hardware
External Power Supply with
NEMA 1-15P Plug (Input: 100-
Features
Splitting, Extending, Multi-Display
● Splits or expands a DisplayPort audio/video signal on two HDMI monitors
Display the same image on each monitor, extend the desktop across them, or display in video wall
mode where monitors are combined to display as one, enlarged monitor
1/4
Cleveland, OH 44122
United States
Supports both 4K (3840 x 2160 at 30 Hz) UHD video and standard 1080p (1920x1080 at 60 Hz) highdefinition video
Video Standards and Protocols
● Supports up to 48-bit Deep Color (16 bits per channel) and video resolutions up to 4K Ultra High
Definition (UHD), 3840 x 2160 @ 30 Hz
Complies with HDCP, EDID and DDC
Compatible with DisplayPort 1.2
Compatible with Apple® Thunderbolt connectors
Installation
● Plug-and-play; no software or drivers required
Easy to install; connect the DisplayPort video source to the hub's input port, connect the external power
supply and finally connect the two HDMI monitors to the output ports
Mounting Options
● Wall-, rack- or pole-mounting; all mounting hardware is included
TAA-Compliant for GSA Schedule Purchases
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332175892
Technology
DisplayPort; HDMI
Host Connector
DISPLAYPORT (MALE)
VIDEO
Max Supported Video Resolution
Max Supported Color Depth
48-bit Deep Color
3D Video Supported
Yes
AUDIO
Audio Specification
DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
2/4
240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Cleveland, OH 44122
United States
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
4.1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) Orange (Monitor Signal); (x1) Green (Power)
PHYSICAL
Color
Black
Material of Construction
Metal
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
2.20 x 6.50 x 7.20
Shipping Dimensions (hwd / cm)
5.59 x 16.51 x 18.29
Shipping Weight (lbs.)
1.04
Shipping Weight (kg)
0.47
Unit Dimensions (hwd / in.)
1.000 x 5.300 x 3.600
Unit Dimensions (hwd / cm)
9.175 x 6.414 x 2.56
Unit Packaging Type
Box
Unit Weight (lbs.)
0.86
Unit Weight (kg)
0.39
ENVIRONMENTAL
Operating Temperature Range
14 to 167 °F (-10 to 75 °C)
Storage Temperature Range
-4 to 176 °F (-20 to 80 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
14 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
Side A - Connector 1
DISPLAYPORT (FEMALE)
Side B - Connector 1
(2) HDMI (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
3/4
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Displayport Specification
1.2
HDCP Specification
1.3
Driver Required
No
MST Support
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
