B132-008A-2
B132-008A-2
    TRIPPLITE
    VGAEXTDR/SPLITTER8-PORT1000FT
B132-008A-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8-Port VGA over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video/Audio, Up to 1000 ft. (305 m), TAA MODEL NUMBER: B132-008A-2 Highlights ● Requires Tripp Lite remote receivers (sold separately) ● Extends 1024 x 768 @ 60 Hz audio/video signal up to 1,000 ft. ● Extends 1920 x 1440 @ 60 Hz audio/video signal up to 500 ft. ● Daisy-chain up to 6 units to extend signal to 49 displays ● Plug and play—no software or drivers to install Package Includes Works with Tripp Lite’s B132-Series receivers to transmit a VGA + audio signal to 9 sets of displays and speakers (8 remote, 1 local) up to 1,000 ft. away. Ideal for digital signs, trade shows and classrooms. Features Transmits a Single High-Definition VGA + Audio Signal to 9 Sets of Displays/Speakers ● Ideal for applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source ● Splits one VGA + audio signal into 9 separate signals (8 remote, 1 local) ● Tripp Lite B132-100A or B132-100A-WP-1 remote receiver required for each remote signal Daisy-Chain Units to Reach More Remote Displays ● Daisy-chain up to 6 units to extend the original audio/video signal to as many as 49 displays (48 remote, 1 local) ● Connects to next link in chain with one Cat5/Cat6 cable, such as Tripp Lite 24 AWG solid-wire N02201K-GY (Cat5e) or N222-01K-GY (Cat6) cable ● Add up to 3 B132-110A remote repeaters to each channel to extend signal range or add displays Extends Signals Up to 1,000 ft. ● Extends a 1920 x 1440 (60 Hz) signal up to 500 ft. away from the audio/video source ● Extends a 1024 x 768 (60 Hz) signal up to 1,000 ft. away from the audio/video source ● Supports high-quality audio Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to source and displays with VGA cable, such as Tripp Lite’s P504-Series ● LEDs indicate at a glance when the unit is receiving power and a VGA signal from the source ● Included mounting hardware lets you install the unit on a wall, rack or pole 1/5 ● B132-008A-2 8-Port VGA + Audio over Cat5/6 Extender Splitter ● External power supply (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● VGA + audio daisy-chain cable, 1 ft. ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332190246 Product Type Transceiver Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 Host Connector HD15 (FEMALE) VIDEO Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 500 Max 1080P Range (ft) 500 Max 1280 x 720 (720p) Range (ft) 500 Max 1920 x 1080 (1080p) Range (ft) 500 Max 1920 x 1200 Range (ft) 500 Transmitter Video Input VGA Transmitter - Number of Video Outputs 8 Transmitter - Local Display Output VGA Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 Maximum Signal Range Details 1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz) AUDIO Audio Input 3.5mm Audio Specification Stereo Audio 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Green); Orange (Activity, EDID) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 8 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.20 x 13.90 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 35.31 x 16.51 Shipping Weight (lbs.) 3.90 Shipping Weight (kg) 1.77 Unit Dimensions (hwd / in.) 1.200 x 9.300 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 23.6 x 9.91 Unit Packaging Type Box Unit Weight (lbs.) 1.5 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.68 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range -4 to 158 (-20 to 70 C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 1000 Max 480P Range (ft) 1000 Max 1440 x 900 Range (ft) 500 Max 1080i Range (ft) 500 Max 1920 x 1440 Range (ft) 500 Max 480i Range (ft) 1000 Max 640 x 480 Range (ft) 1000 Max 800 x 600 Range (ft) 1000 Max 1600 x 1200 Range (ft) 500 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 8 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (8) RJ45 (FEMALE) Side B - Connector 2 HD15 (FEMALE) Side B - Connector 3 3.5MM (FEMALE) PORT EXPANSION Daisy-chainable or Cascadable Cascadeable FEATURES & SPECIFICATIONS Driver Required No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B132-008A-2 价格&库存
很抱歉,暂时无法提供与“B132-008A-2”相匹配的价格&库存,您可以联系我们找货
