B126-2A1
B126-2A1
    TRIPPLITE
    HDMIEXTENDERKIT1X2200FT
B126-2A1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1 x 2 HDMI over Cat5/6 Extender Kit, Box-Style Transmitter/Receiver for Video/Audio, Up to 150 ft. (45 m), TAA MODEL NUMBER: B126-2A1 Highlights ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install ● Built-in equalization control lets you adjust monitor image System Requirements Package Includes Transmitter and receiver work in tandem to extend an HDMI signal via a single Cat5e/6 cable to 2 projectors, monitors or televisions. Ideal for digital signs, schools and trade show presentations. Description The B126-2A1 HDMI over Cat5/Cat6 Extender Kit includes a transmitter unit and a receiver unit that work in tandem to extend an HDMI signal to two projectors, monitors or televisions. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. HDMI cable (see Tripp Lite's P568-Series) connects the local monitor and the audio/video source to the transmitter's HDMI ports and two monitors to the receiver. Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) connects the two units. The B126-2A1 can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). You can connect up to three B126-110 remote repeaters in the chain for a maximum of six HDMI displays and full signal extension of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) or 400-ft. (121.92 m) (3D). In addition to crystal-clear video, the B126-2A1 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio. Built-in equalization control lets you fine-tune the image quality at each remote display. Supports 24-bit True Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m) ● Connect up to 3 B126-110 remote repeaters to the chain for maximum signal range of 700-ft. (213.36 m) (1080i), 500-ft. (152.4 m) (1080p) and 400-ft. (121.92 m) (3D) ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) 1/5 ● Transmitter unit ● Receiver unit ● Screwdriver for adjusting equalization ● (2) External Power Supplies with NEMA 1-15P Plug(Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m) ● Mounting hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP ● Built-in equalization control lets you adjust the image on the local monitor Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Units connect quickly to monitors with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and a signal from the previous link in the chain ● Included mounting hardware lets you install the units on a wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180735 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 Host Connector HDMI (FEMALE) VIDEO Video Input HDMI (FEMALE) Video Output HDMI (FEMALE) Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 200 ft @ 1080i150 ft @ 1080p AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) PHYSICAL Color Black 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Receiver Unit Dimensions (hwd / cm.) 2.54 x 6.35 x 9.14 Receiver Unit Dimensions (hwd / in.) 1 x 2.5 x 3.6 Receiver Unit Weight (kg) 0.09 Receiver Unit Weight (lbs.) 0.2 Shipping Dimensions (hwd / in.) 8.40 x 6.50 x 2.20 Shipping Dimensions (hwd / cm) 21.34 x 16.51 x 5.59 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Transmitter Unit Dimensions (hwd / cm.) 2.54 x 6.35 x 9.14 Transmitter Unit Dimensions (hwd / in.) 1 x 2.5 x 3.6 Transmitter Unit Weight (kg) 0.09 Transmitter Unit Weight (lbs.) 0.2 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 200 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HDMI (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; RoHS; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-2A1 价格&库存
很抱歉,暂时无法提供与“B126-2A1”相匹配的价格&库存,您可以联系我们找货
