B126-004
B126-004
    TRIPPLITE
    HDMIEXTDR/SPLITTER4-PORT200FT
B126-004 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port HDMI over Cat5/6 Extender/Splitter, BoxStyle Transmitter for Video/Audio, Up to 150 ft. (45 m), TAA MODEL NUMBER: B126-004 Highlights ● Perfect for digital signs, trade shows and classrooms ● Can daisy-chain up to 3 units to extend signal to 13 monitors ● Works with all operating systems and HDMI video sources ● Supports stereo and 7.1channel surround sound audio ● Includes an HDMI cable with latching connectors for a more secure connection ● Plug and play—no software or drivers to install System Requirements Package Includes Works with Tripp Lite’s B126-Series receivers to split a single HDMI signal into five separate signals (one local and four remote), each on one cable, to five projectors, monitors or televisions in a chain. ● B126-004 4-Port HDMI over Cat5/Cat6 Extender/Splitter ● HDMI daisy-chain cable with latching connectors, 12 in. ● External Power Supply (Input: 100-240V, 50/60 Hz, 1.0A; Output: 5V, 3A, 5-ft. (1.52 m) ● Mounting hardware ● Owner's Manual Description The B126-004 4-Port HDMI over Cat5/Cat6 Extender/Splitter works with Tripp Lite B126-Series remote receivers to split a single HDMI audio/video signal into five separate signals—one local and four remote. It's ideal for digital signs, trade shows, presentations, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. It uses HDMI cable (see Tripp Lite's P568-Series) to connect to the source and the local monitor and Cat5e/6 cable to transmit to the remote monitors (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). When used with Tripp Lite's B126-1A0 or B126-1A0-WP-1 active remote receivers, the Extender/Splitter can extend a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p signal (60 Hz) up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m). With a B126-1P0 or B126-1P0-WP-1 passive remote receiver, it can extend a 1080i (60 Hz) signal up to 100-ft. (30.5 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m). By daisy-chaining up to three Extender/Splitters, one video source can transmit to as many as 13 monitors—one local and 12 remote. Add up to three B126-110 remote repeaters to each channel to fully extend the signal range or add more displays. In addition to crystal-clear video, the B126-004 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Included HDMI cable with latching connectors provides a more secure connection. Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 175-ft. (53.34 m), a 1080p (60 Hz) signal up to 125-ft. (38.1 m) and a 3D signal up to 100-ft. (30.5 m) with each optional Tripp Lite B126-110 remote repeater ● Extends a 1080i (60 Hz) signal up to 200-ft. (60.96 m), a 1080p (60 Hz) signal up to 150-ft. (45.72 m) and a 3D signal up to 125-ft. (38.1 m) with Tripp Lite B126-1A0 or B126-1A0-WP-1 active remote receiver ● Extends a 1080i (60 Hz) signal up to 100-ft. (30.5 m) and a 1080p (60 Hz) signal up to 50-ft. (15.24 m) with Tripp Lite B126-1P0 or B126-1P0-WP-1 passive remote receiver ● Add up to 3 remote repeaters on each channel for maximum signal range ● Daisy-chain up to 3 units to extend the original signal to as many as 13 display monitors (1 local, 12 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States remote) ● Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to source and local monitor with HDMI cable, such as Tripp Lite's P568-Series ● LEDs indicate at a glance when the unit is receiving power and an HDMI signal from the source ● Included mounting hardware lets you install the unit on a wall, rack or pole ● Included HDMI cable with latching connectors provides a more secure conntection ● Mount up to 3 units in 1U of rack space using a Tripp Lite B132-004-RB rack-mount bracket TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332157515 Product Type Transceiver Technology HDMI; Cat5/5e; Cat6 Host Connector HDMI (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max. Distance (Between any 2 Units) 16ft (5m) Max Number of Ports (Entire Chain) 12 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 4 Transmitter - Local Display Output HDMI 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Range Extension using other Tripp Lite product 175ft @ 1080i 125ft @ 1080p Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B126-110 Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 200 ft @ 1080i150 ft @ 1080p AUDIO Audio Input 3.5mm Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Transmitter end only (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power), Orange (Activity) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Steel Included Mounting Accessories Wallmount Number of Displays 4 Optional Mounting Accessory Notes Up to three transmitters local units can be mounted in 1U of rack space using a Tripp Lite  B132-004RB  Extender/Splitter 19in rackmount bracket. Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount; Rackmount Rackmountable Yes Shipping Dimensions (hwd / in.) 2.00 x 8.30 x 6.40 Shipping Dimensions (hwd / cm) 5.08 x 21.08 x 16.26 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.86 x 12.7 x 10.16 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Signal Range (ft.) 200 Signal Range (m) 61 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 4 Side A - Connector 1 (2) HDMI (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) PORT EXPANSION Daisy-chainable or Cascadable Daisy chainable FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-004 价格&库存
很抱歉,暂时无法提供与“B126-004”相匹配的价格&库存,您可以联系我们找货
B126-004
    库存:1
