B126-004-INT
B126-004-INT
    TRIPPLITE
    HDMIEXTDR/SPLITTER4-PORT200FT
B126-004-INT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port HDMI over Cat5/6 Extender/Splitter, BoxStyle Transmitter, Video/Audio, 1080/60p up to 150ft, Intl Power Supply MODEL NUMBER: B126-004-INT Highlights ● Perfect for digital signs, trade shows and classrooms ● Can daisy-chain up to 3 units to extend signal to 13 monitors ● Works with all operating systems and HDMI video sources ● Supports stereo and 7.1channel surround sound audio ● Plug and play—no software or drivers to install Package Includes Works with Tripp Lite’s B126-Series receivers to split a single HDMI signal into 5 separate signals (one local and four remote), each on one cable, to 5 projectors, monitors or televisions up to 200 feet (61 m) away. Description The B126-004-INT 4-Port HDMI over Cat5/Cat6 Extender/Splitter works with Tripp Lite B126-Series remote receivers to split a single HDMI audio/video signal into five separate signals—one local and four remote. It’s ideal for digital signs, trade shows, presentations, retail settings and other applications where the video source is located farther than conventional cables allow or that require multiple displays connected to one source. The B126-004-INT uses HDMI cable (see Tripp Lite’s P568-Series) to connect to the source and the local monitor and Cat5e/6 cable to transmit to the remote monitors (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite’s N202-Series). When used with Tripp Lite’s B126-1A0 or B126-1A0-WP-1 active remote receivers, the B126-004-INT can extend a 1080i (60 Hz) signal up to 200 feet (61 m), a 1080p signal (60 Hz) up to 150 feet (45.7 m) and a 3D signal up to 125 feet (38.1 m). With a B126-1P0 or B126-1P0-WP-1 passive remote receiver, it can extend a 1080i (60 Hz) signal up to 100 feet (30.5 m) and a 1080p (60 Hz) signal up to 50 feet (15.2 m). By daisy-chaining up to three B126-004-INT units, one video source can transmit to as many as 13 monitors—one local and 12 remote. Add up to three B126-110 remote repeaters to each channel to fully extend the signal range or add more displays. Easy to set up with no software or drivers to install, the unit mounts to a wall, rack or pole using the included hardware. 1/4 ● B126-004-INT 4-Port HDMI over Cat5/Cat6 Extender/Splitter ● HDMI daisy-chain cable, 12 in. (30.5 cm) ● External power supply w/CEE 7/16 Schuko, BS1363 UK and AS2112 Australia plugs (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Features Extends High-Definition Signals ● Extends a 1080i (60 Hz) signal up to 175 ft. (53.3 m), a 1080p (60 Hz) signal up to 125 ft. (38.1 m) and a 3D signal up to 100 ft. (30.5 m) with each optional Tripp Lite B126-110 remote repeater ● Extends a 1080i (60 Hz) signal up to 200 ft. (61 m), a 1080p (60 Hz) signal up to 150 ft. (45.7 m) and a 3D signal up to 125 ft. (38.1 m) with Tripp Lite B126-1A0 or B126-1A0-WP-1 active remote receiver ● Extends a 1080i (60 Hz) signal up to 100 ft. (30.5 m) and a 1080p (60 Hz) signal up to 50 ft. (15.2 m) with Tripp Lite B126-1P0 or B126-1P0-WP-1 passive remote receiver ● Add up to 3 remote repeaters on each channel for maximum signal range ● Daisy-chain up to 3 units to extend the original signal to as many as 13 display monitors (1 local, 12 remote) ● Connects to next link in the chain with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite’s N202-Series) Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio ● Supports 24-bit True Color (8 bits per channel) and HDCP Easy to Set Up and Use ● Plug and play—no software or drivers to download and install ● Connects quickly to source and local monitor with HDMI cable, such as Tripp Lite’s P568-Series ● LEDs indicate when the unit is receiving power and an HDMI signal from the source ● Included mounting hardware lets you install the unit on a wall, rack or pole ● Mount up to 3 units in 1U of rack space using a Tripp Lite B132-004-RB rack-mount bracket ● International power supply with CEE 7/16 Schuko, BS1363 UK and AS2112 Australia plugs Specifications OVERVIEW UPC Code 037332192776 Product Type Cat5/Cat6 Transmitter Technology HDMI VIDEO Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 PHYSICAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Included Mounting Accessories Yes Optional Mounting Accessory Notes Up to three  B126-004  local units can be mounted in 1U of rack space using a Tripp Lite  B132-004-RB  Extender/Splitter 19in rackmount bracket Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 5.00 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 12.70 Shipping Weight (lbs.) 1.76 Shipping Weight (kg) 0.80 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.86 x 12.7 x 10.16 ENVIRONMENTAL Operating Temperature Range 0 to 40 C (32 to 104 F) Storage Temperature Range -20 to 60 C (-4 to 140 F) Relative Humidity 20 to 90% COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 200 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 CONNECTIONS Number of Ports 4 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B126-004-INT
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件具有低导通电阻和快速开关特性,适用于高速信号处理。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
B126-004-INT 价格&库存
很抱歉,暂时无法提供与“B126-004-INT”相匹配的价格&库存,您可以联系我们找货
