B126-1A1-SC4K
B126-1A1-SC4K
    TRIPPLITE
    HDMIOVERCAT5/CAT6ACTIVEEXTEN
B126-1A1-SC4K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/Cat6 Active Extender Kit, Transmitter and Receiver with Built-In 4K x 2K (@ 24Hz) Upscaler, 125 ft., TAA MODEL NUMBER: B126-1A1-SC4K Highlights ● Upscales 1080p signal (@ 24 Hz) to 4K x 2K (@ 24 Hz) ● Upscales 480p and 720p signals to 1080p ● Supports stereo and 7.1channel surround sound ● Built-in equalization control lets you adjust monitor image ● Plug and play—no software or drivers required System Requirements ● Computer, Blu-ray™ player or other source with HDMI output ● 4K-capable display(s) with HDMI input Package Includes ● Receiver unit ● Transmitter unit ● (2) External power supplies w/NEMA 1-15P plug (Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Screwdriver for adjusting equalization The B126-1A1-SC4K HDMI over Cat5/Cat6 Active Extender Kit includes a transmitter unit and a receiver ● Mounting hardware unit that work in tandem to extend an HDMI audio/video signal to an HDMI projector, monitor or television. ● Owner’s manual Transmitter and receiver work in tandem to upscale 480p/720p HDMI signals to 1080p or 1080p signals (@ 24 Hz) to 4K x 2K (@ 24 Hz) and extend them via Cat5e/6 cable to an HDMI display up to 125 ft. Description It also upscales the HDMI signal to convert 480p and 720p to 1080p or convert 1080p (@ 24 Hz) to 4K x 2K (@ 24 Hz). It’s recommended for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. Cat5e/6 cable connects the transmitter and receiver units (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite’s N202-Series). Each unit is powered by included external power supplies that connect to a secure AC outlet. Use HDMI cables (such as Tripp Lite’s P569-Series locking cables) to connect the units to the audio/video source and the display. You can also connect an optional second HDMI display (maximum 1080p video resolution) to the transmitter’s local port. The plug-and-play B126-1A1-SC4K can extend a converted 4K x 2K (@ 24 Hz) signal up to 125 feet with full, rich stereo or 7.1-channel surround sound (multi-channel or PCM). It’s HDCP-compliant, works with 3D video signals and supports 24-bit True Color (8 bits per channel). Built-in equalization control lets you fine-tune the image quality at the display. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends HDMI Audio/Video Signals to an HDMI Display ● Extends a converted 4K x 2K (@ 24 Hz) signal or a 3D signal up to 125 ft. ● Recommended for digital signs, trade shows, presentations, classrooms, churches and retail settings 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports stereo, 7.1-channel surround sound and 24-bit True Color ● 3D and HDCP compliant Upscales a 1080p HDMI Signal (@ 24 Hz) to 4K x 2K (@ 24 Hz) ● Also upscales 480p and 720p signals to 1080p Easy to Set Up and Use ● Plug and play—no software or drivers required ● Mounts to wall, rack or pole using the included hardware ● Optional HDMI port on transmitter allows connection of local monitor (max 1080p) ● Built-in equalization control lets you adjust the image ● Works with all operating systems Specifications OVERVIEW UPC Code 037332196323 Product Type Cat5/Cat6 Extender Kit Technology HDMI VIDEO Max 720P Range (ft) 125 Max 1080P Range (ft) 125 Max 1920 x 1200 Range (ft) 125 Max 2560 x 1600 Range (ft) 125 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.10 x 6.30 x 8.40 Shipping Dimensions (hwd / cm) 5.33 x 16.00 x 21.34 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 COMMUNICATIONS Max 1024 x 768 Range (ft) 125 Max 480P Range (ft) 125 Max 1440 x 900 Range (ft) 125 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1080i Range (ft) 125 Max 1920 x 1440 Range (ft) 125 Max 480i Range (ft) 125 Max 640 x 480 Range (ft) 125 Max 800 x 600 Range (ft) 125 Max 1600 x 1200 Range (ft) 125 Max 2048 x 1536 Range (ft) 125 CONNECTIONS Number of Ports 5 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B126-1A1-SC4K 价格&库存
很抱歉,暂时无法提供与“B126-1A1-SC4K”相匹配的价格&库存,您可以联系我们找货
