B140-002-DD
B140-002-DD
    TRIPPLITE
    DVIEXTDR/SPLTTRDUAL2PRT200FT
B140-002-DD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DVI over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video, Dual-Display DVI-D, 200 ft. (60 m), TAA Highlights ● Split and extend Dual DVI signals from a computer to two sets of Dual Displays ● 1920 x 1200 (60Hz) resolution up to 150-ft. (45.72 m) ● Up to 4 displays per channel when using repeaters ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-002-DD System Requirements Package Includes Split and extend Dual DVI signals from a computer to two sets of Dual Displays Description Tripp Lite's B140-002-DD takes in two PC DVI source video signals, and splits each to two remote monitors. Passive, non-powered Receivers allow distances up to 50-ft. (15.24 m) @ 1920x1200 resolution, or 100-ft. (30.5 m) @ 1024x768 resolution, over solid conductor Cat6 cable. Active, powered Receivers extend the distance to 150-ft. (45.72 m) @ 1920x1200, and 200-ft. (60.96 m) @ 1024x768 (receivers purchased separately). Additional monitors can be daisy-chained (up to 3) on each channel, allowing four monitors per channel, by using Tripp Lite B140-110 Repeater/Extender. Tripp Lite recommends Cat6 Solid Conductor patch cables for Digital Extenders (DVI/HDMI). Tripp Lite N202-series patch cables are designed specifically for these types of devices...pre-terminated, Solid Conductor Cat6 patch cables up to 200-ft. (60.96 m). Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Transmits a DVI-D Single-Link signal from a set of Dual DVI inputs to two sets of Dual Displays ● A B140-Series remote receiver is needed at each monitor ● For longer distances: Use a B140-1A0 active receiver to extend a 1920 x 1200 @ 60Hz signal up to 150-ft. (45.72 m) from the transmitter (or a 1024 x 768 @ 60Hz signal up to 200-ft. (60.96 m) from the transmitter) ● For shorter distances: Use a B140-1P0 passive receiver to extend a 1920 x 1200 @ 60Hz signal up to 50-ft. (15.24 m) from the transmitter (or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) from the transmitter) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series to achieve maximum distance and resolution ● Further expand the range and number of monitors by adding B140-110 remote repeater units ● Add up to three repeaters on each of the B140-002-DD channels, for a total of 4 displays per channel (An active receiver should be the last unit in a channel) ● A 1920 x 1200 @ 60Hz signal can be extended up to 125-ft. (38.1 m) for each repeater added into a channel (or up to 175-ft. (53.34 m) for a 1024 x 768 @ 60Hz signal) ● DVI 1.0 compliant ● HDCP compatible 1/4 ● B140-002-DD Extender / Splitter Transmitter Unit ● External Power Supply with NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A ) ● Mounting Hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Mounting hardware included that allows the unit to be wall-mounted, rackmounted, or pole mounted ● Plug and play; no software or drivers required ● Compatible with all operating systems ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332177513 Product Type Transceiver Technology DVI; Cat5/5e; Cat6 Host Connector HD15 (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-I Transmitter - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.17 x 8.43 x 6.46 Shipping Dimensions (hwd / cm) 5.51 x 21.41 x 16.41 Shipping Weight (lbs.) 1.54 Shipping Weight (kg) 0.70 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 3.05 x 12.7 x 9.14 Unit Packaging Type Box Unit Weight (lbs.) 0.8 Unit Weight (kg) 0.36 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 1 (4) RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-002-DD 价格&库存
很抱歉,暂时无法提供与“B140-002-DD”相匹配的价格&库存,您可以联系我们找货
