B119-4X4
B119-4X4
    TRIPPLITE
    HDMIMATRIXSWITCH4X41920X1080
B119-4X4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4x4 HDMI Matrix Switch with Remote Control 1080p @ 60 Hz (HDMI 4xF/4xF), TAA MODEL NUMBER: B119-4X4 Highlights ● Share multiple HDMI sources between multiple monitors ● Supports video resolutions up to 1920 x 1200 (1080p) @ 60Hz ● Plug-and-play; No software or drivers required Package Includes Connect 4 HDMI source devices to 4 HDMI displays and switch video signals between them. Description Tripp Lite B119-4X4 is a 4x4 HDMI Matrix Switch that routes high definition video from any four HDMI sources to any four HDMI displays. It supports video resolutions up to 1920 x 1200 (1080p) @ 60Hz. The 4x4 Matrix eliminates the need to disconnect and reconnect HDMI sources. It works with any HDMI source that connects to an HDMI display, and each source is accessible at all times by any display by selecting it with an IR remote, or using the RS232 port to switch the unit. Features ● Share multiple HDMI sources between multiple monitors ● Allows any input to be routed to any output; or the same input to be routed to multiple outputs ● Switch between inputs via pushbuttons, remote control, or RS-232 serial ● Monitors can be located up to 25 ft. from the switch ● Supports video resolutions up to 1920 x 1200 (1080p) @ 60Hz ● HDCP and EDID compatible ● Mounting hardware included ● Plug-and-play; No software or drivers required ● Compatible with all operating systems ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180179 Technology HDMI; IR 1/3 ● B119-4X4 Local Transmitter Unit ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 3A) ● 3.5 mm to DB9 Adapter Cable ● IR Extension Cable, 5 ft. ● Mounting Hardware ● Remote Control ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Supported Resolutions 1920x1080 (1080p) POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 4.0 External Power Supply Cord Length (m.) 1.2 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A PHYSICAL Color Black Included Mounting Accessories Yes Rackmountable No Shipping Dimensions (hwd / in.) 2.10 x 6.30 x 13.70 Shipping Dimensions (hwd / cm) 5.33 x 16.00 x 34.80 Shipping Weight (lbs.) 2.30 Shipping Weight (kg) 1.04 Unit Dimensions (hwd / in.) 1.200 x 9.200 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 23.37 x 9.91 Unit Weight (lbs.) 1.45 Unit Weight (kg) 0.66 COMMUNICATIONS Port Control Push Buttons Signal Range (ft.) 60 Signal Range (m) 18 IP Remote Access Yes EDID Compatible Yes RS-232 Serial Extension Support Yes CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 4 Side A - Connector 1 (4) HDMI (FEMALE) Side B - Connector 1 (4) HDMI (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B119-4X4 价格&库存
很抱歉,暂时无法提供与“B119-4X4”相匹配的价格&库存,您可以联系我们找货
