B156-004-HD
B156-004-HD
    TRIPPLITE
    MSTHUBDISPLYPORTTOHDMI4-PRT
B156-004-HD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States ● ● ● A computer with a DisplayPort v1.2 compatible Graphics Card (e.g. AMD Radeon with AMD Eyefinity technology) is required to display in video wall mode. Backward compatible with most DisplayPort 1.1a equipment running current graphics drivers, with the feature set being limited to that of your equipment (e.g. you may be limited to displaying in Clone / Mirror mode only). Compatibility with older graphics cards is not guaranteed. MST-compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps amongst all monitors with higher resolution monitors using up more bandwidth. 1080p monitors will use up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display settings interface of your graphics card. If the total percentage of bandwidth taken up by all the connected monitors exceeds 100%, an image will not display on one or more of them. Highlights ● DisplayPort 1.2 compliant ● Display the same image on each monitor, extend the desktop across them, or display in video wall mode where monitors are combined to display as one ● Supports video resolutions up to 1920 x 1080 on each monitor. Displaying all four monitors in video wall mode allows for expanded resolutions up to 3840 x 2160 @ 24/30Hz 4K UHD. ● Supports up to 48-bit Deep Color (16 bits per channel) ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Maximum supported video resolutions and number of monitors will be dependent upon your graphics card. Check the specifications of your graphics card to determine its capabilities. 4-Port DisplayPort to HDMI Multi-Monitor Splitter, MST Hub, 4K 60Hz, DP1.2, TAA MODEL NUMBER: B156-004-HD System Requirements ● A computer with a DisplayPort v1.2 compatible Graphics Card (e.g. AMD Radeon with AMD Eyefinity technology) is required to display in video wall mode. ● Mac OS X does not support MST for NVIDIA and Intel Graphics Processor Units, limiting video display on the connected monitors to mirror mode. ● Backward compatible with most DisplayPort 1.1a equipment running current graphics drivers, with the feature set being limited to that of your equipment (e.g. you may be limited to displaying in Clone / Mirror Mode only). Compatibility with older graphics cards is not guaranteed. ● MST-compliant graphics cards are limited to a bandwidth of 21.6 Gbps amongst all monitors with higher resolution monitors using up more bandwidth. 1080p monitors will use up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display settings interface of your graphics card. If the total percentage of bandwidth taken up by all the connected monitors exceeds 100%, an image will not display on one or more of Ideal for digital signage in schools, airports and other venues that require a DisplayPort signal to be distributed to four HDMI monitors in mirror mode, extended mode, or video wall mode. Description Tripp Lite's B156-004-HD 4-Port DisplayPort 1.2 to HDMI MST Hub allows you to connect four independent HDMI monitors to a single DisplayPort output on your computer. Connect to a Mini DisplayPort output, or the Thunderbolt port on your Mac, using a Mini DisplayPort to DisplayPort cable (Tripp Lite P583-Series). You can display the same image on each monitor, extend the desktop across them, or display in video wall mode where monitors are combined to display as one, enlarged monitor. The B156-004-HD supports video resolutions up to 1920 x 1080 (1080p) on each connected monitor. Expanded video resolutions are supported when displaying all four monitors in video wall mode, such as 3840 x 2160 @ 24/30Hz in a 2X2 monitor configuration, or 7680 x 1080 in a vertical 4X1 monitor configuration. It supports 48-bit Deep Color (16 bits per channel), DTS-HD, Dolby True HD and 7.1 channel surround sound audio, and is compatible with HDCP, EDID and DDC. It comes with an external power supply and brackets for wall-, rack- or pole-mounting. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Splitting, Extending, Video Wall Mode ● Connect four independent HDMI monitors to a single DisplayPort output on your computer them. ● A monitor with a HDMI port. ● Display the same image on each monitor, extend the desktop across them, or display in video wall mode where monitors are combined to display as one, enlarged monitor ● Supports video resolutions up to 1920 x 1080 (1080p) on each connected monitor. ● ● Expanded video resolutions are supported when displaying all four monitors in video wall mode, such as 3840 x 2160 @ 24/30Hz in a 2X2 monitor configuration, or 7680 x 1080 in a vertical 4X1 monitor configuration. B156-004-HD DisplayPort 1.2 to HDMI Multi-Stream Transport (MST) Hub ● Mounting Hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.) Video Standards and Protocols ● Supports up to 48-bit Deep Color (16 bits per channel) ● Compatible with HDCP, EDID and DDC ● DisplayPort 1.2 compliant ● Compatible with Apple® Thunderbolt connectors when using a Mini DisplayPort to DisplayPort cable (Tripp Lite P583-Series) Installation ● Plug-and-play; no software or drivers required ● Easy to install; connect the DisplayPort video source to the hub's input port, connect the external power supply and finally connect the four HDMI monitors to the output ports ● Connect to a Mini DisplayPort output, or the Thunderbolt port on your Mac, using a Mini DisplayPort to DisplayPort cable (Tripp Lite P583-Series) Mounting Options ● Wall-, rack- or pole-mounting; mounting hardware is included TAA-Compliant for GSA Schedule Purchases ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332186928 Technology DisplayPort; HDMI Host Connector DISPLAYPORT (MALE) VIDEO Max Supported Video Resolution 4K @ 60Hz (3840 x 2160) Max Supported Color Depth 48-bit Deep Color 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio 2/4 Package Includes 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V, 50/60Hz, 0.5A External Power Supply Output Specs (V / A) 5V, 2A External Power Supply Cord Length (ft.) 4.5 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 7 USER INTERFACE, ALERTS & CONTROLS LED Indicators (x1) Green (Power) PHYSICAL Color Black Material of Construction Metal Rackmountable No Shipping Dimensions (hwd / in.) 8.43 x 6.46 x 2.20 Shipping Dimensions (hwd / cm) 21.41 x 16.41 x 5.59 Shipping Weight (lbs.) 0.65 Shipping Weight (kg) 0.29 Unit Dimensions (hwd / in.) 1.170 x 5.040 x 3.930 Unit Dimensions (hwd / cm) 12.8 x 10 x 2.97 Unit Dimensions (hwd / mm) 128 x 100 x 19.7 Unit Packaging Type Box Unit Weight (lbs.) 0.56 Unit Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 14 to 167 °F (-10 to 75 °C) Storage Temperature Range -4 to 176 °F (-20 to 80 °C) Relative Humidity 0% to 85%, Non-Condensing BTUs 23.9 BTU/Hr COMMUNICATIONS EDID Compatible Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 4 Side A - Connector 1 DISPLAYPORT (FEMALE) Side B - Connector 1 (4) HDMI (FEMALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Displayport Specification 1.2 HDCP Specification 1.3 Driver Required No MST Support Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B156-004-HD 价格&库存
很抱歉,暂时无法提供与“B156-004-HD”相匹配的价格&库存,您可以联系我们找货
