B126-1A1SR
B126-1A1SR
    TRIPPLITE
    HDMIEXTDRKIT3840X2160328FT
B126-1A1SR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Extender Kit, Transmitter/Receiver, 4K, Serial and IR Control, Up to 328 ft. (100 m), TAA Highlights ● Extends a 3840 x 2160 (4K x 2K) @ 24/30Hz signal up to 328.08-ft. (100 m) ● Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD ● Controls RS-232 serial devices at baud rates up to 115 Kbps ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install MODEL NUMBER: B126-1A1SR Package Includes Transmit HDMI video and audio, RS-232 serial and IR Remote Control signals over a single Cat5e/6/6a cable up to 328 ft. to a projector, monitor or television. Ideal for digital signs and trade show presentations. ● Transmitter unit ● Receiver unit ● (2) IR-IN cables ● (2) IR-OUT cables ● 3.5 mm Male to DB9 Female adapter cable ● 3.5 mm Male to DB9 Male adapter cable ● (2) External Power Supplies with NEMA 1-15P Plug(Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 3A) ● Mounting hardware ● Owner’s Manual Description The B126-1A1SR HDMI over Cat5/Cat6 Extender Kit includes a transmitter unit and a receiver unit that work in tandem to extend HDMI audio and video, RS-232 serial and IR Remote Control signals to a projector, monitor or television. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. How far you can extend the signals depends on the cable you use to connect the transmitter and receiver. You can extend a 3840 x 2160 (4K x 2K) Ultra High Definition (UHD) signal @ 24/30Hz up to 328.08-ft. (100 m) with a single Cat6a cable, up to 230-ft. (70.1 m) with a 24 AWG solid-wire Cat6 cable (Tripp Lite's N202-Series), and up to 150-ft. (45.72 m) with a 26 AWG solid-wire Cat5e cable (N001- and N002Series). For extending computer video resolutions of 1920 x 1200 @ 60 Hz or high-definition video resolutions of 1080p @ 60 Hz up to 328.08-ft. (100 m), use a single 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series. You can also control RS-232 serial devices, such as touchscreen displays or scanners, at baud rates up to 115 Kbps. The B126-1A1SR supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio, as well as 3D video and HDCP. Easy to set up with no software or drivers to install. Mounts to a wall, rack or pole using the included hardware. Features Extends High-Definition Signals ● 328 ft. (100 m) with a single Cat6a cable (custom-ordered from Tripp Lite) ● 230-ft. (70.1 m) with a 24 AWG solid-wire Cat6 cable (N202-Series) ● 150-ft. (45.72 m) with a 26 AWG solid-wire Cat5e cable (N001- and N002-Series) 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio ● Supports 3D video and HDCP Allows You to Control Other Display Devices ● 2-way 39 KHz IR Remote Control functionality lets you control your Blu-ray player with its remote while standing at the remote monitor (and vice versa) ● RS-232 serial port supports 115 Kbps full-duplex baud rates for scanners and touchscreen monitors Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Units connect quickly to source and display with HDMI cable (P568-Series) ● Included mounting hardware lets you install each unit on a wall, rack or pole TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332171108 Product Type Extender Kit Technology HDMI; IR; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 3840x2160 (4K @ 30Hz) Max 1280 x 720 (720p) Range (ft) 328 Max 1920 x 1080 (1080p) Range (ft) 328 Max 1920 x 1200 Range (ft) 328 Max 2560 x 1600 Range (ft) 328 Max 3840 x 2160 (4K@30Hz) Range (ft) 328 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 328 Maximum Signal Range (m) 100 AUDIO Audio Input HDMI Audio Output HDMI Audio Specification 7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Green (Power), Orange (Activity) PHYSICAL Color Black Material of Construction Steel 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-01  Form Factor/Mounting Options Box; Wall-mount Rackmountable Yes Receiver Unit Dimensions (hwd / cm.) 2.7 x 11.5 x 6.24 Receiver Unit Dimensions (hwd / in.) 1.1 x 4.5 x 2.5 Receiver Unit Weight (kg) 0.39 Receiver Unit Weight (lbs.) 0.85 Shipping Dimensions (hwd / in.) 2.00 x 6.20 x 11.30 Shipping Dimensions (hwd / cm) 5.08 x 15.75 x 28.70 Shipping Weight (lbs.) 2.40 Shipping Weight (kg) 1.09 Transmitter Unit Dimensions (hwd / cm.) 2.7 x 11.5 x 6.24 Transmitter Unit Dimensions (hwd / in.) 1.1 x 4.5 x 2.5 Transmitter Unit Weight (kg) 0.39 Transmitter Unit Weight (lbs.) 0.85 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Signal Range (ft.) 328 Signal Range (m) 100 EDID Compatible Yes IR Remote Extension Support Yes RS-232 Serial Extension Support Yes Consumer Electronics Control (CEC) Supported Yes 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States USB Extension Support No CONNECTIONS Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 (3) 3.5MM (FEMALE) Side A - Connector 3 RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 (3) 3.5MM (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No Recommended Category Cable Cat5/Cat5e/Cat6 Cables 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; RoHS; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B126-1A1SR 价格&库存
很抱歉,暂时无法提供与“B126-1A1SR”相匹配的价格&库存,您可以联系我们找货
