1000 Eaton Boulevard
Cleveland, OH 44122
United States
48-Port Console Server with USB - Built-In
Modem, Dual GbE NIC, 16 Gb Flash, 1U Rack,
TAA
Highlights
Manage routers, UPS systems
and other serial-based
equipment from anywhere 24/7
Validated to meet FIPS 140-2
standards to ensure utmost
protection of private data
Dual 10/100 Ethernet ports for
primary network connection and
automatic failover
Advanced authentication with
LDAP, RADIUS, TACACS+ and
Kerberos servers
USB ports connect to PDUs and
UPS systems with remote
management abilities
MODEL NUMBER: B096-048
Applications
48-port console server lets you remotely access and control serial-based networking equipment through
one highly secure gateway.
Securely access and control
servers, routers, KVM switches
and other serial-connected
devices in your data center 24/7
Manage diverse server and
device platforms using a
network connection
Diagnose and fix issues with
your IT infrastructure remotely
with little or no downtime
Troubleshoot equipment issues
without spending time/money
traveling to remote locations
Features
Access All Your Serial and Network Devices from Anywhere in the World at Any TimeThis USB
console server provides secure in-band (primary network) and out-of-band (alternate channel) remote
access to serial- and network-connected routers, network switches, firewalls, PBX systems, UPS systems,
PDUs and other devices. It offers reliable network connectivity with dual Gigabit primary and failover
Ethernet ports (the second port can also be used as a gateway port) and dual power supplies. You can
use the B096-048 in a wide variety of locations, including wiring closets, branch offices, kiosks, point-ofsale and other remote sites where a quick identification and resolution of network issues is imperative.
Simple and Flexible AccessibilityThe 48 RJ45 ports are configured to use standard Cat5e/6 patch cable
when connecting to Cisco devices. They integrate with industry-standard directory servers using
TACACS+, RADIUS, LDAP and Kerberos authentication. 16 Gb of internal NAND flash memory can be
used for log storage and file storage.
Built-In V.92 Modem for Out-of-Band AccessA serial data/fax modem enables 3G cellular out-of-band
(alternate channel) access when remote sites experience a network outage. You can dial into the rack
console from anywhere at any time, eliminating the costly need for additional USB modems that can be
accidentally disconnected or have compatibility issues. However, if desired, you may connect one of the
RJ45 ports to an external Multitech MT9234MU-CDC-XR or US Robotics USR5637 USB modem (not
included) to receive out-of-band access.
Router/GatewayEach gateway can port forward to an unlimited number of locally networked hosts
(computers, routers). This rack console also includes a built-in stateful firewall and embedded DHCP
server to host a separate management LAN for critical traffic.
The Utmost in Security to Keep Your Sensitive Data PrivateThis 48-port console server supports the
following security features and standards: FIPS 140-2, SSL and SSH, stateful firewall, OpenVPN and
IPSec VPN. The embedded FIPS 140-2 OpenSSL cryptographic module is validated to meet FIPS 140-2
standards and has received Certificate #1051.
PowerMan PDU and UPS SupportThis IP terminal server uses PowerMan for PDU and RPC
1/3
Package Includes
B096-048 48-Port Serial Server
with USB
(2) Cat5 patch cables, 6 ft.
DB9 to RJ45 straight connector
DB9 to RJ45 crossover
connector
(2) C13 to NEMA 5-15P power
cords, 6 ft.
Rack-mounting hardware
CD with owner’s manual
Quick Start Guide
Cleveland, OH 44122
United States
management and Network UPS Tools for UPS system monitoring and management. It provides support
for Tripp Lite and other power products, so you can remotely manage power to your connected
equipment.
USB PortsTwo USB 2.0 ports and one USB 1.0 port allow connection to newer devices with USB ports,
such as Tripp Lite’s wide variety of PDUs and UPS systems with WEBCARDLX or other LX Platform
remote management cards.
Compact Design for Convenient MountingThe heavy-duty steel housing comes with mounting brackets
for 1U installation in an EIA-standard 19-inch rack.
TAA-Compliant for GSA Schedule PurchasesThe B096-048 is compliant with the Federal Trade
Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and
other federal procurement contracts.
Specifications
OVERVIEW
UPC Code
037332148919
Multi-User
Yes
INPUT
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Maximum Input Amps
0.8
Input Connection Type
2 x IEC-320-C14, Auto-Switching 100-240VAC
Input Frequency
50/60HZ
Input Current
120V (0.11A) / 230V (0.06A)
POWER
Power Consumption (Watts)
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
3.50 x 19.60 x 16.10
Shipping Dimensions (hwd / cm)
8.89 x 49.78 x 40.89
Shipping Weight (lbs.)
11.10
Shipping Weight (kg)
5.03
Unit Dimensions (hwd / in.)
1.750 x 17.400 x 12.500
Unit Dimensions (hwd / cm)
4.445 x 44.2 x 31.75
Unit Weight (lbs.)
8.70
Unit Weight (kg)
3.95
2/3
Cleveland, OH 44122
United States
ENVIRONMENTAL
Storage Temperature Range
Non operating storage temperature: -30C to +60C (-20F to +140F)
Relative Humidity
Humidity: 5% to 90%
Operating Temperature
Ambient operating temperature: 5C to 50C (41F to 122F)
BTUs
120V: 68 BTU per hour
COMMUNICATIONS
IP Remote Access
Yes
Network Compatibility
100 Mbps (Fast Ethernet)
CONNECTIONS
Number of Ports
48
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
4-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B096-048”相匹配的价格&库存,您可以联系我们找货
