B132-002A
B132-002A
    TRIPPLITE
    VGAEXTENDER2-PORT1000FT
B132-002A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA + Audio over Cat5 Extender 2-Port Transmitter MODEL NUMBER: B132-002A Highlights ● Splits a single VGA Video and Audio signal into 2 ● Extends a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● 2 Port Extender/Splitter local (Transmitter) unit ● Mounting hardware ● External power supply (Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A) ● Owner Manual Description Tripp Lite's B132-002A allows you to split a single VGA Video and Audio signal into 2. Along with a B132100A or B132-100A-WP-1 remote receiver unit, you can extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted. Ideal for digital signage situations, such as retail, schools, churches, etc. Features ● Splits a single VGA Video and Audio signal into 2 ● When used with a B132-100A or B132-100A-WP-1 remote receiver unit, you can extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N22201K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted. ● Ideal for digital signage situations, such as retail, shools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332155511 Product Type Cat5/Cat6 Transmitter 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Stereo Audio; VGA/SVGA POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 1.000 x 2.500 x 3.600 Unit Dimensions (hwd / cm) 2.54 x 6.35 x 9.14 Unit Weight (lbs.) 0.45 Unit Weight (kg) 0.20 CONNECTIONS Number of Ports 2 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (2) RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B132-002A 价格&库存
很抱歉,暂时无法提供与“B132-002A”相匹配的价格&库存,您可以联系我们找货
