B132-004-1
B132-004-1
    TRIPPLITE
    VGA OVER CAT5 EXTENDER 4-PORT
B132-004-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5 Extender, 4-Port Transmitter Highlights ● Splits a single VGA signal into 5 (1 local, 4 remote) ● Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B132-004-1 Package Includes ● 4 Port Extender/Splitter local (Transmitter) unit ● 1 ft. VGA daisychain cable Description ● Mounting hardware Tripp Lite's B132-004-1 allows you to split a single VGA signal into 5 (1 local, 4 remote). Increase the ● External power supply (Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A) ● Owner's Manual number of displays to up to 25 (1 local, 24 remote) by daisy-chaining up to six B132-004-1 units together. Along with a B132-100-1 or B132-100-WP-1 remote receiver unit, you can extend a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal video image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted. Up to three B132-004-1 units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB Extender/Splitter 19 in. rackmount bracket. Ideal for digital signage situations, such as retail, schools, churches, etc. Features ● Splits a single VGA signal into 5 (1 local, 4 remote) ● Increase the number of displays to up to 25 (1 local, 24 remote) by daisychaining up to six B132-004-1 units together ● A B132-100-1 or B132-100-WP-1 remote receiver unit is required for each connected monitor ● Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted ● Up to three B132-004-1 units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB Extender/Splitter 19 in. rackmount bracket ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332160140 Product Type Cat5/Cat6 Transmitter Technology VGA/SVGA POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.20 x 8.40 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 21.34 x 16.51 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 1.200 x 5.300 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 13.46 x 9.91 Unit Weight (lbs.) 0.85 Unit Weight (kg) 0.39 CONNECTIONS Number of Ports 4 Side A - Connector 1 HD15 (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 HD15 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B132-004-1 价格&库存
很抱歉,暂时无法提供与“B132-004-1”相匹配的价格&库存,您可以联系我们找货
