B132-004A
B132-004A
    TRIPPLITE
    VGA + AUDIO OVER CAT5 EXT 4-PORT
B132-004A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port VGA with Audio over Cat5 / Cat6 Extender Splitter, Transmitter, 1920x1440 at 60Hz MODEL NUMBER: B132-004A Highlights ● Splits a single VGA Video and Audio signal into 5 (1 local, 4 remote) ● Support for video resolutions up to 1920 x 1440 (60Hz) ● Extends a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● 4 Port Extender/Splitter local (Transmitter) unit ● 1 ft. VGA + Audio daisychain cable Increase the number of displays/speakers to up to 25 (1 local, 24 remote) by daisychaining up to six ● Mounting hardware B132-004A units together. Along with a B132-100A or B132-100A-WP-1 remote receiver unit, you can ● External power supply (Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A) ● Owner's Manual Description Tripp Lite's B132-004A allows you to split a single VGA Video and Audio signal into 5 (1 local, 4 remote). extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01KGY (Cat5) and N222-01K-GY (Cat6). Support for video resolutions up to 1920 x 1440 (60Hz). For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted. Up to three B132004A units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB Extender/Splitter 19 in. rackmount bracket. Ideal for digital signage situations, such as retail, schools, churches, etc. Features ● Splits a single VGA Video and Audio signal into 5 (1 local, 4 remote) ● Increase the number of displays/speakers to up to 25 (1 local, 24 remote) by daisychaining up to six B132-004A units together ● When used with a B132-100A or B132-100A-WP-1 remote receiver unit, you can extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N22201K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Support for video resolutions up to 1920 x 1440 (60Hz) ● Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted ● Up to three B132-004A units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB Extender/Splitter 19 in. rackmount bracket ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332148766 Product Type Cat5/Cat6 Transmitter Technology Stereo Audio; VGA/SVGA POWER AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.20 x 8.40 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 21.34 x 16.51 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 1.200 x 5.300 x 3.900 Unit Dimensions (hwd / cm) 3.05 x 13.46 x 9.91 Unit Weight (lbs.) 0.85 Unit Weight (kg) 0.39 CONNECTIONS Number of Ports 4 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 HD15 (FEMALE) Side B - Connector 3 3.5MM (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B132-004A 价格&库存
很抱歉,暂时无法提供与“B132-004A”相匹配的价格&库存,您可以联系我们找货
