1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI Splitter, 2-Port
Highlights
Supports computer video
resolutions up to 1920 x 1200,
and HD resolutions up to 1080p
HDCP compliant
Connects to both HDMI and
DVI-D Single-Link displays
ATC certified
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B118-302-R
System Requirements
Description
TV's with an available HDMI
port and a HDMI peripheral
device (e.g. Blu-Ray player,
DVR, etc.)
The cable connecting the HDMI
source to the splitter must be no
longer than 16 ft. (5 m.), unless
using a signal booster (B122000-60 or B123-001-60)
The cable connecting the splitter
to a HDMI monitor must be no
longer than 25 ft. (7.62 m.)
Tripp Lite's HDMI Splitter allows the digital signal from a Blu-Ray player or other HDMI device, to be
displayed on multiple HDMI or DVI-D Single Link monitors. Supports computer video resolutions up to
1920 x 1200, and HD resolutions up to 1080p. Up to 32 displays can be connected by cascading up to
three levels of additional splitters. Locate a monitor up to 41 ft. (12.5 m.) from a HDMI source; up to 16 ft.
Package Includes
B118-302-R 2-Port HDMI
Splitter
Splitters can be located up to 100 ft. away from the source using a combination of Tripp Lite long length
1 ft. HDMI cable
HDMI cables ( P568-050, P568-100-HD ) and a HDMI Signal Booster (B122-000-60 or B123-001-60).
Mounting hardware
Includes mounting hardware that allows the unit to be wallmounted, rackmounted or pole mounted.
External Power Supply (Input:
100-240V, 50/60Hz, 0.4A
Output: 5V, 2A)
Owner's Manual
(5 m.) between the source and the splitter; up to 25 ft. (7.62 m.) between the splitter and a monitor.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Features
Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p.
HDCP compliant
Supports 3D, Lip-Sync Pass Through, and CEC Pass Through
Connects to both HDMI and DVI-D Single-Link displays
Cascade up to three levels of splitters to support up to 32 displays
Includes mounting hardware that allows the unit to be wallmounted, rackmounted, or pole mounted
Locate a monitor up to 41 ft. (12.5 m.) from a HDMI source; up to 16 ft. (5 m.) between the source and
the switch; up to 25 ft. (7.62 m.) between the switch and a monitor
ATC certified
Specifications
OVERVIEW
1/2
Cleveland, OH 44122
United States
UPC Code
037332144157
Technology
HDMI
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.4A; Output: 5V, 2A, 4.9ft
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
2.12 x 7.25 x 6.50
Shipping Dimensions (hwd / cm)
5.40 x 18.42 x 16.51
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
CONNECTIONS
Number of Ports
2
Side A - Connector 1
HDMI (FEMALE)
Side B - Connector 1
(2) HDMI (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“B118-302-R”相匹配的价格&库存,您可以联系我们找货
