B119-302-R
B119-302-R
    TRIPPLITE
    HDMISWITCH2-PORT1920X1200
B119-302-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI Switch, 2-Port Highlights ● Connect two HDMI devices to a single HDMI port ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. ● Supports Deep Color ● HDCP compliant ● HDMI cable included ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B119-302-R System Requirements ● TV with an available HDMI port and HDMI peripheral devices ● The cable connecting the HDMI source to the switch must be no longer than 16 ft. (5 m.) ● The cable connecting the switch to a HDMI monitor must be no longer than 25 ft. (7.62 m.) Description Tripp Lite's 2-Port HDMI switch allows you to connect two HDMI devices, such as a Blu-Ray player or Sony PS3, to a single HDMI port. The unit supports 10.2Gbps signal rates, as well as computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. Transmits both audio and video signals. Includes mounting hardware that allows the unit to be wallmounted, rackmounted, or pole mounted. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Package Includes ● 2-Port HDMI Switch ● 1 ft. HDMI cable ● Mounting hardware ● External Power Supply (Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A) ● Owner's Manual Features ● Connect two HDMI devices to a single HDMI port ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. ● Supports Deep Color ● HDCP compliant ● Supports 3D, Lip-Sync Pass Through, and CEC Pass Through ● HDMI cable included ● Includes mounting hardware that allows the unit to be wallmounted, rackmounted or pole mounted ● Locate a monitor up to 41 ft. (12.5 m.) from a HDMI source; up to 16 ft. (5 m.) between the source and the switch; up to 25 ft. (7.62 m.) between the switch and a monitor ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332145994 Technology HDMI POWER 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 1.2A, 4.9ft PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B119-302-R 价格&库存
很抱歉,暂时无法提供与“B119-302-R”相匹配的价格&库存,您可以联系我们找货
