B140-1P0-WP
B140-1P0-WP
    TRIPPLITE
    DVIEXTDRWALLPLATECAT5/6100FT
B140-1P0-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI Over Cat5 Passive Extender Remote Wallplate MODEL NUMBER: B140-1P0-WP Highlights ● For use with B140-002 or B140004 extender/splitter transmitter units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 50 ft., or a 1024 x 768 @ 60Hz signal up to 100 ft. ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Compatible with all operating systems ● Plug and play, no external power, software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Transmit a DVI-D Single-Link signal up to 100 ft. away using a single Cat5e/6 patch cable Package Includes Description ● B140-1P0-WP DVI Over Cat5 Passive Extender Remote Wallplate transmitter units, and it transmits a DVI-D Single-Link signal up to 100 ft. away using a single Cat5e/6 ● Wallplate screws patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp ● 110 punchdown tool ● Owner's manual The B140-1P0-WP is a receiver wallplate that is used with the B140-002 and B140-004 extender/splitter Lite's N202-Series). The B140-1P0-WP is compatible with all operating systems, and is plug and play, with no external power, software or drivers required. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Installation is simple. Connect a B140-002 or B140-004 transmitter (not included) to a DVI source using a Tripp Lite P561-Series DVI cable (not included). Connect the B140-1P0-WP to a display using a Tripp Lite P561-Series DVI cable (not included). Finally, the receiver unit is connected to an RJ45 port on the transmitter unit using a single Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 50 ft. from the source,, or a 1024 x 768 @ 60Hz signal up to 100 ft.. Features ● Transmit a DVI-D Single-Link signal up to 100 ft. away using a single Cat5e/6 patch cable ● For use with B140-002 or B140-004 extender/splitter transmitter units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 50 ft., or a 1024 x 768 @ 60Hz signal up to 100 ft. ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● HDCP compatible ● Compatible with all operating systems ● Plug and play; no external power, software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332156662 Product Type Cat5/Cat6 Receiver Technology DVI PHYSICAL Color White Included Mounting Accessories Yes Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 11.43 x 6.99 x 2.54 CONNECTIONS Number of Ports 1 Side A - Connector 1 110 IDC Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B140-1P0-WP 价格&库存
很抱歉,暂时无法提供与“B140-1P0-WP”相匹配的价格&库存,您可以联系我们找货
