301-2157-01
301-2157-01
    DIGIINTERNATIONAL
    HUBPORT4C+INT'L4PORTUSBPS
301-2157-01 数据手册
USB Plus Series Powered USB Solutions USB PlusPower technology saves space and simplifies retail and medical system architecture by eliminating individual power supply bricks for USB peripheral devices. Overview USB peripheral devices such as bar-code scanners, receipt printers and signature capture devices are common elements of traditional retail/POS systems. Many of these devices require external power supply bricks, which can create a tangled mess of cables and power strips. This takes up valuable space and creates more potential points of failure. USB PlusPower, or powered USB technology, was developed to eliminate external power supply bricks for USB devices. Its unique cabling allows USB devices to receive power from the USB PlusPower device instead of external power supplies. Migrating to USB PlusPower devices traditionally required a specialized, expensive retail system. The USB Plus Series makes it easy to connect powered USB peripheral devices to a basic PC. The USB Plus Series can save space and simplify system architecture by transforming a low-cost PC into a high-performance, powered USB-compatible retail system. Each product offers four powered USB ports with cable locking mechanisms, which are also compatible with standard USB devices. Application Highlight Touch Screen Monitor RS-232 Retail/POS Cash Drawer CAT5 Hubport + ® c ort/4 bp Hu USB Powered USB Printer PC Bar-Code Scanner Signature Pad Features/Benefits • Eliminate individual power supply bricks for USB peripheral devices • Supplies power and communication signals over hot-pluggable USB cable Target Applications • Enables a low-cost, standard PC to become a high performance POS/POC system • Cable locking mechanism ensures secure connection image to come • Compatible with standard and powered USB peripheral devices Retail/POS Medical/Healthcare • Power balancing technology provides maximum power to 12-volt and 24-volt peripherals, without exhausting the PC’s 5- or 12-volt power www.digi.com Specifications Hubport®/4c+ Interfaces USB PlusPower Ports Port 1 supplies 24 VDC, and Ports 2 through 4 supply 12 VDC USB PlusPower Data Rates Active General Features Form Factor External hub LEDs Tri-state LED for device status and port activity Windows® 8, Windows 2012, Windows 7, Windows Vista®, Windows Server® 2008, Windows XP®, Windows XP Embedded, Windows CE, Windows Server® 2003 and Windows 2000 Operating Systems 2.61 in x 3.00 in x 1.00 in (6.63 cm x 7.62 cm x 2.54 cm) Dimensions (L x W x H) Weight 4.20 oz (118.00 g) Cables 10 in (25.4 cm) captive cable Other Compatible with standard (type A) and locking powered USB connectors; Locking power connector; Plug and Play; Convection cooled design; Full hardware and software flow control Power Requirements Power Input Standard external power supply included: 72 watt avg., 90 watt peak 100-240V, 50/60 Hz, 1.6 Amp Power Output 12V: up to 30 watts; 24V: up to 60 watts; All combined: up to 72 watts Power balancing technology for efficient power management; Port level power management (toggles 12V/24V power); Meets power switching requirements of USB 1.1 specification Power Features Environmental Operating Temperature 0° C to 65° C (32° F to 149° F) Relative Humidity 0% to 95% (non-condensing) Regulatory Approvals Safety EN60950, UL 1950, CSA 2.2 No. 950, IEC 950 Emissions/Immunity CE, FCC Part 15 Class B, EN55022, EN55024 You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support Digi International Worldwide HQ 877-912-3444 952-912-3444 www.digi.com Digi International France +33-1-55-61-98-98 www.digi.fr Digi International Japan +81-3-5428-0261 www.digi-intl.co.jp Digi International Singapore +65-6213-5380 91001221 H4/613 Digi International China +86-21-50492199 www.digi.com.cn © 1996-2015 Digi International Inc. All rights reserved. All other trademarks are the property of their respective owners. www.digi.com
301-2157-01 价格&库存
很抱歉,暂时无法提供与“301-2157-01”相匹配的价格&库存,您可以联系我们找货
