DC-DTS-B100
DC-DTS-B100
    DIGIINTERNATIONAL
    DIGIDIALSERV
DC-DTS-B100 数据手册
PRELIMINARY Product Datasheet Digi DialServ™ RJ-11 Phone Line Simulator Digi DialServ is an RJ-11 PSTN analog modem to RS-232 serial converter that seamlessly integrates with Digi cellular gateway products to provide communications across local or wide area networks to legacy devices with embedded modems. Central Office Ethernet Digi DialServ™ X L NA H SIG ENGT STR LIN C  K AC TIV E N WA VP N DC X 0V 9-3 mA MA 525 R PW TUS STA D T RESET ERNE T ETH K AC LIN Serial Se Digi Cellu Cellular lula lu larr G la Gateway atew Features/Benefits • When used in conjunction with Digi cellular VPN gateways: - Connects legacy devices with built-in modem to LAN/WAN - Converts RJ-11 PSTN analog modem to RS-232 serial for compatibility with Digi cellular gateways - Simulates Telco network and converts phone number to IP address - Built-in secure VPN connection (IPsec, SSL) – even over public network - Dial-in/Dial-out support • Easy integration with Digi products, including Digi Connect® WAN, ConnectPort™ WAN VPN, and ConnectPort™ X cellular gateways www.digi.com D ialS RJ-11 er v Link E Act OL C 30VD25 9 to- 11A 37A NS er AU CO Pow VPN Internet/ Frame Relay/ VPN Wireless Telco Network RTU (With Built-in Analog Modem) Overview Digi DialServ is an RJ-11 phone line simulator that allows legacy devices with built-in modems to communicate across LANs/WANs. Using seamless integration to Digi cellular and Ethernet gateways, Digi DialServ provides secure IPsec or SSL VPN connections – even over public networks. When used with Digi cellular gateways, Digi DialServ works with both dial-in and dial-out applications by simulating the Telco network and converting the requested phone number to an IP address. This allows remote devices with a built-in modem (and an RJ-11 port) to seamlessly communicate with a centralized location as if they were TCP/IP devices. Replacing old phone lines with IP communications allows customers to leverage higher availability, lower-cost networks, while potentially reducing monthly recurring costs related to phone bills. Also, devices using Digi DialServ over high speed IP networks often realize much faster transaction time versus slow dial-up modems. Digi DialServ requires virtually no configuration, making it very easy to deploy. Simply plug the RJ-11 cable from your existing device into a Digi DialServ, which is connected to a Digi cellular gateway via serial cable. Now incoming and outbound calls will be seamlessly converted to IP connections. Common applications for Digi DialServ include SCADA (industrial automation, utilities, etc.), retail/point-of-sale and building automation/security, and infrastructure including devices such as ATMs, RTUs, kiosks, security panels, credit card/payment terminals and pay-at-the-pump controllers. Features/Specifications REGULATORY APPROVALS (Pending) FEATURES ENVIRONMENTAL • When used in conjunction with Digi cellular gateways: - Converts analog/PSTN data to IP/packet data - Data routing methods ° Fixed IP address ° Phone number as IP address ° Look-up table for IP address based on phone number ° Passing phone number to fixed IP address for routing ° Secure IPsec and SSL tunneling available with Digi VPN gateways - Fully configurable through Web UI of the attached cellular gateway • Integrated mounting brackets • V.34 support with full error correction and compression • Supports all modem connection rates from 300 baud to 33.6 Kbaud • Integrated off-hook and transmit LEDs • Power connector with locking plug • Operating temperature: 0° C to 70° C (32° F to 158° F) • Relative humidity: 5% to 95% (non-condensing) • • • • • • • • FCC Part 15, Class B EN55022 EN55024 UL60950 CSA 22.2 No. 60950 EN60950 VCCI V-3/99 .05 AS/NZS 3548 POWER REQUIREMENTS DIMENSIONS • Power input: 9-30VDC • Ability to share power with attached gateway • Y cable for power included • • • • Length: 3.9 in (9.9 cm) Width: 1.7 in (4.3 cm) Depth: 1.0 in (2.5 cm) Weight: 2.3 oz (65.2 g) Digi DialServ - Front INTERFACES Power Y Cable • RJ-11 for modem connection • Female DB-9 DCE serial for cellullar gateway connection • Compatible with Digi products, including Digi Connect WAN, ConnectPort WAN VPN, and ConnectPort X cellular gateways Allows Digi DialServ to share power with Digi Connect WAN or ConnectPort cellular products. DB-9F Serial Digi DialServ - Back MODEL......................PART NUMBERS Model Worldwide Digi DialServ - RJ-11 to RS-232 Converter (Dial & Answer Mode) DC-DTS-B100 RJ-11 DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here WHEN to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 11001 Bren Road E. Minnetonka, MN 55343 U.S.A. PH: 877-912-3444 952-912-3444 FX: 952-912-4952 email: info@digi.com Digi International France Digi International KK Digi International (HK) Limited 31 rue des Poissonniers 92200 Neuilly sur Seine PH: +33-1-55-61-98-98 FX: +33-1-55-61-98-99 www.digi.fr NES Building South 8F 22-14 Sakuragaoka-cho, Shibuya-ku Tokyo 150-0031, Japan PH: +81-3-5428-0261 FX: +81-3-5428-0262 www.digi-intl.co.jp Suite 1703-05, 17/F., K Wah Centre 191 Java Road North Point, Hong Kong PH: +852-2833-1008 FX: +852-2572-9989 www.digi.cn 9-30VDC Power MATTERS™ Digi International, the leader in device networking for business, develops reliable products and technologies to connect and securely manage local or remote electronic devices over the network or via the web. With over 20 million ports shipped worldwide since 1985, Digi offers the highest levels of performance, flexibility and quality. www.digi.com © 2007 Digi International Inc. Digi, Digi International, the Digi logo, the When Reliability Matters logo, ConnectPort, Digi Connect and Digi DialServ are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. 91001422 A1/807
DC-DTS-B100 价格&库存
很抱歉,暂时无法提供与“DC-DTS-B100”相匹配的价格&库存,您可以联系我们找货
