N784-001-SC-15
N784-001-SC-15
    TRIPPLITE
    EXTERNALMULTIMODEMEDIACONVERT
N784-001-SC-15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10/100 SC Singlemode Fiber to Ethernet Media Converter, 15km, 1310nm MODEL NUMBER: N784-001-SC-15 Highlights ● Extends a 100Mb Ethernet signal up to 15kM over Singlemode Fiber Optic Cable ● Auto detects Full/Half Duplex Transfer Mode ● Supports Singlemode cable up to 15 KM System Requirements ● 10/100 Ethernet Network ● Singlemode SC Fiber cable Package Includes Extend an Ethernet connection up to 15kM over Singlemode Fiber Description Tripp Lite's N784-001-SC-15, 10/100 to Singlemode Media Converter ( RJ45 to SC ), is an economical way to extend the distance ( up to 15kM ) of network nodes by converting Cat5e UTP cables to Singlemode Fiber Optic. The Media Converter features automatic MDI/MDI-X configuration, and the UTP port senses the network speed automatically as well. Auto-detects half or full duplex operation on the fiber port. Power supplied by small form factor AC adapter. Features ● 10/100 UTP to Singlemode Fiber converter ● Up to 15kM ( 9 mile ) range ● Auto-detects Full / Half Duplex Transfer Mode ● Auto Negotiation MDI / MDI-X ● 6 performance monitoring LEDs ● 1310nm wavelength ● Small, compact design ● Supports Singlemode cable up to 15 KM Specifications OVERVIEW UPC Code 037332184139 Product Type Fiber to Ethernet Technology Cat5/5e; Singlemode Mode Type Singlemode 1/3 ● N784-001-SC-15 Media Converter ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz; Output: 5V, 1.2A) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States DISPLAY Accessories (Included) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 5V/2A) NETWORK Network Ports RJ45 (FEMALE); SC (FEMALE) POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.2A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.53 External Power Supply Cord Length (m.) 1.38 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 1.2A DC Barrel Plug OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Power LED), L/A (Fiber port connection indicator), SD (Fiber signal indicator), SPD (Network speed), TP-L/A (Copper port connection indicator), FDX/COL (Full Duplex/Half Duplex) PHYSICAL Color Black Power Cord Color Black Shipping Dimensions (hwd / in.) 3.70 x 1.02 x 2.76 Shipping Dimensions (hwd / cm) 9.40 x 2.59 x 7.01 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.54 x 11.94 x 6.99 Unit Packaging Type Box Unit Weight (lbs.) 1.00 Unit Weight (kg) 0.45 Housing Metal ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range -4 to 140°F (-20 to 60°C) Storage Temperature Range -4 to 158°F (-20 to 70°C) Relative Humidity 5 to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) Network Speed Details 10 Mbps; 100 Mbps Wavelength 1310nm Transmission Distance 15 km Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 SC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 10 Mbps; 100 Mbps Auto MDIX Support Yes DIN Mountable No Mounting Accessory Included No Working Mode Full/Half Duplex Optical Port SC STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; cUL; WEEE Product Compliance RoHS; CE (Europe); FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N784-001-SC-15 价格&库存
很抱歉,暂时无法提供与“N784-001-SC-15”相匹配的价格&库存,您可以联系我们找货
