N784-001-SC-MM
N784-001-SC-MM
    TRIPPLITE
    EXTERNAL MULTIMODE MEDIA CONVERT
N784-001-SC-MM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10/100 SC Multimode Fiber to Ethernet Media Converter, 550M, 850nm MODEL NUMBER: N784-001-SC-MM Highlights ● Extends a 100Mb Ethernet signal up to 550M over Multimode Fiber Optic Cable ● Auto detects Full/Half Duplex Transfer Mode ● Supports Multimode 50/125 cable up to 2KM or 62.5/125 cable up to 550M System Requirements ● 10/100 Ethernet Network ● Multimode SC Fiber cable Package Includes Extend an Ethernet connection up to 550 Meters over Multimode Fiber Description Tripp Lite's N784-001-SC-MM 10/100 to Multimode Media Converter ( RJ45 to SC ) is an economical way to extend the distance of network nodes up to 550 Meters by converting Cat5e UTP cables to Multimode Fiber Optic. The Media Converter features automatic MDI/MDI-X configuration, and the UTP port senses the network speed automatically. Auto-detects half or full duplex operation on the fiber port. Power supplied by small form factor AC adapter. Features ● 10/100 UTP to SC Multimode Fiber converter ● Up to 550M ( 1800ft ) range ● Auto-detects Full / Half Duplex Transfer Mode ● Auto Negotiation MDI / MDI-X ● 6 performance monitoring LEDs ● 850nm wavelength ● Small, compact design ● Supports Multimode 50/125 cable up to 2KM or 62.5/125 cable up to 550M Specifications OVERVIEW UPC Code 037332183934 Product Type Fiber to Ethernet Technology Cat5/5e; Multimode Mode Type Multimode 1/3 ● 10/100 SC Multimode Media Converter, 550M, 850nm ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz; 5V, 1.2A) ● User Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States DISPLAY Accessories (Included) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 5V/2A) NETWORK Network Ports RJ45 (FEMALE); SC (FEMALE) POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.2A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.53 External Power Supply Cord Length (m.) 1.38 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 1.2A DC Barrel Plug OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Power LED), L/A (Fiber port connection indicator), SD (Fiber signal indicator), SPD (Network speed), TP-L/A (Copper port connection indicator), FDX/COL (Full Duplex/Half Duplex) PHYSICAL Color Black Power Cord Color Black Shipping Dimensions (hwd / in.) 9.06 x 2.17 x 4.92 Shipping Dimensions (hwd / cm) 23.01 x 5.51 x 12.50 Shipping Weight (lbs.) 0.86 Shipping Weight (kg) 0.39 Unit Dimensions (hwd / in.) 1.020 x 2.760 x 3.700 Unit Dimensions (hwd / cm) 2.54 x 11.94 x 6.99 Unit Packaging Type Box Unit Weight (lbs.) 1.00 Unit Weight (kg) 0.45 Housing Metal ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range -4 to 140°F (-20 to 60°C) Storage Temperature Range -4 to 158°F (-20 to 70°C) Relative Humidity 5 to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet) Network Speed Details 10 Mbps; 100 Mbps Wavelength 850nm Transmission Distance 550 m Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 SC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 10 Mbps; 100 Mbps Auto MDIX Support Yes DIN Mountable No Mounting Accessory Included No Working Mode Full/Half Duplex Optical Port SC STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; cUL; WEEE Product Compliance RoHS; CE (Europe); FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N784-001-SC-MM 价格&库存
很抱歉,暂时无法提供与“N784-001-SC-MM”相匹配的价格&库存,您可以联系我们找货
