N785-001-SC-MM
N785-001-SC-MM
    TRIPPLITE
    FIBER MEDIA CONVERTER RJ45 SC
N785-001-SC-MM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Gigabit Multimode Fiber to Ethernet Media Converter, 10/100/1000 SC, 550 m, 850 nm MODEL NUMBER: N785-001-SC-MM Highlights ● Extends a Gigabit Ethernet signal up to 550M over Multimode Fiber Optic Cable ● Auto detects Full/Half Duplex Transfer Mode ● Supports Multimode 50/125 cable up to 550M or 62.5/125 cable up to 400M System Requirements ● 10/100/1000 Ethernet Network ● Multimode SC Fiber cable Package Includes ● N785-001-SC-MM Gigabit Multimode Fiber to Ethernet Media Converter, 550 m, 850 nm ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz; Output: 5V, 1.2A) ● User Manual Extend an Ethernet connection up to 550 Meters over Multimode Fiber Description Tripp Lite's N785-001-SC-MM Gigabit Multimode Fiber to Ethernet Media Converter is an economical way to extend the distance of network nodes up to 550 Meters by converting Cat5e UTP cables to Multimode Fiber Optic. The Media Converter features automatic MDI/MDI-X configuration, and the UTP port senses the network speed automatically. Auto-detects half or full duplex operation on the fiber port. Power supplied by small form factor AC adapter. Features ● 10/100/1000 UTP to Multimode Fiber converter ● Up to 550M ( 1800 ft ) range ● Auto-detects Full / Half Duplex Transfer Mode ● Auto Negotiation MDI / MDI-X ● 6 performance monitoring LEDs ● 850nm wavelength ● Small, compact design ● Supports Multimode 50/125 cable up to 550M or 62.5/125 cable up to 400M Specifications OVERVIEW UPC Code 037332184146 Product Type Fiber to Ethernet Technology Cat5/5e; Cat6; Multimode Mode Type Multimode 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States DISPLAY Accessories (Included) External Power Supply (Input: 100-240V, 50/60Hz, 0.5A; Output: 5V/2A) NETWORK Network Ports RJ45 (FEMALE); SC (FEMALE) POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.2A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.53 External Power Supply Cord Length (m.) 1.38 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 1.2A DC Barrel Plug OD: 5.5 x 2.5 x 11mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators PWR (Power LED), L/A (Fiber port connection indicator), SD (Fiber signal indicator), SPD (Network speed), TP-L/A (Copper port connection indicator), FDX/COL (Full Duplex/Half Duplex) PHYSICAL Color Black Power Cord Color Black Shipping Dimensions (hwd / in.) 9.06 x 2.17 x 4.92 Shipping Dimensions (hwd / cm) 23.01 x 5.51 x 12.50 Shipping Weight (lbs.) 0.86 Shipping Weight (kg) 0.39 Unit Dimensions (hwd / in.) 1.020 x 2.760 x 3.700 Unit Dimensions (hwd / cm) 2.54 x 11.94 x 6.99 Unit Packaging Type Box Unit Weight (lbs.) 1.00 Unit Weight (kg) 0.45 Housing Metal ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32 to 140 F (0 to 60 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 5 to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 10 Mbps; 100 Mbps (Fast Ethernet); 1 Gbps (Gigabit) Network Speed Details 10 Mbps; 100 Mbps; 1000 Mbps Wavelength 850nm Transmission Distance 550 m Wavelength Division Multiplexing (WDM) Yes CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 SC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 1 Gbps; 10 Mbps; 100 Mbps Auto MDIX Support Yes DIN Mountable No Mounting Accessory Included No Working Mode Full/Half Duplex Optical Port SC STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; cUL; WEEE Product Compliance RoHS; CE (Europe); FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N785-001-SC-MM 价格&库存
很抱歉,暂时无法提供与“N785-001-SC-MM”相匹配的价格&库存,您可以联系我们找货
