CG0192-11897
CG0192-11897
    OPTION
    CLOUDGATE GATEWAY 3G AMERICAS
CG0192-11897 数据手册
3G Americas CONNECTING THINGS to the Cloud • Simple, value priced WWAN M2M IP connectivity • Automatic connection monitoring and error recovery • Secure, redundant firmware and configuration images • Unique software and hardware configuration flexibility • Automatic provisioning of custom middleware CONNECTING THINGS to the Cloud Simple, value priced WWAN M2M IP connectivity The CloudGate provides competitively priced LAN to WWAN routing and GPS functionality in a single basic unit certified on all major US cellular operators. The CloudGate is simple to configure locally or remotely from your PC, tablet or SmartPhone. Features Sub Feature WWAN Modem Supported frequency bands Max. Connectivity speeds Reliable and secure CloudGate automatically resolves common problems associated with wireless M2M connectivity. Built in software and hardware watchdogs continuously monitor each component of the product and the product’s connectivity to home servers. In the event an issue is detected, the product proactively takes steps to re-establish connectivity. All software and configuration images are protected with digital signatures and have dual rollback images that allow the product to revert to previous working settings if an issue is detected. All management functions are protected by certificate and/or password based security mechanisms and all management actions take place over hardware assisted encrypted links. Flexible and cost effective to integrate and deploy CloudGate provides unique flexibility that allows customers and system integrators to tailor the product to their solution or even site specific requirements. CloudGate incorporates two hardware expansion slots that allow the CloudGate to be enhanced with additional radio and/or wired interfaces. The expansion cards are simple and quick to install, allowing the field upgrade of the device when new functionality is required. All the design details of the expansion card are available to partners allowing you to add value with your own hardware products. CloudGate allows simple integration and provisioning of customer or third party middleware and applications. The automated cloud provisioning system means that each device can be set with its own custom configuration and image that is automatically loaded from the cloud when it initially connects to the internet. • 1 x SMA: WWAN Main • 1 x SMA: WWAN Div/GPS Assisted/Standalone GPS USIM/SIM connection Industrial serial card Ethernet switch Telematics card SDK + HDK Developer card Breadboard card • Expansion board for IO functions such as serial, USB, GPIO, WiFi Power DC Power in Connector type • 9-33 V DC • Micro-Fit 3.0™, Dual Row, 4 Circuits Current consumption • All measurements at 12V DC • CloudGate attached to 2G network, no Ethernet: 121mA. • CloudGate attached to 2G network, Ethernet connected: 136mA • CloudGate attached to 2G network, no Ethernet, 2G call (2Tx, 32dBm): 270mA, peak = 772mA • CloudGate attached to 3G network, no Ethernet, 3G call @ 2100MHz (band I): 341mA Dimensions (w x d x h) • 115 mm × 105 mm × 45 mm Weight Operating temperature • 294 g • 6 through holes for M4 bolts - 2 x 2 compatible with VESA Mount MIS-D 75 (Optional standard DIN rail mounting interface) • -30°C to 70°C Storage temperature • -40°C to +85°C Humidity operational • 5% - 95% non condensing Certification • FCC • IC • PTCRB • IFETEL Standards compliance • ROHS, Reach SDK + HDK As part of the continual product improvement process, OPTION reserves the right to alter the specifications of this product. © 2014 OPTION. Option and the Option logo are registered trademarks of OPTION. All third-party trademarks are the property of the respective owners. Option nv - Gaston Geenslaan 14 - 3001 Leuven Belgium - T +32 16 317 411 - F +32 16 207 164 1. Configure CloudGate provisioning server • USIM/SIM connection – Class B and Class C 2. Configuration & middleware are automatically installed www.option.com 3. Device is ready to connect things to the Cloud! DataSheet_v1.1 WLAN expansion card Low cost serial card • Standalone GPS, Assisted GPS, gps OneXTRA™ • Wideband GPS processing (20MHz) for improved measurement accuracy • 10/100 Mbps RJ45 Connector Expansion Slot 1&2 Enviromentals • Seven 3 color LEDs showing system status and signal strength • ARM926EJ-S @ 450MHz • Memory available for customer applications: - 30 Mb R/O flash for executables - 30 Mb R/W flash shared with system - 40 Mb free RAM - 1 Mb Configuration data Mounting Also available CloudGate Connectors Ethernet (IEEE 802.3) Case • HSPA+: 14.4 Mbps (Cat 10) down 5.76 (Cat 6) up • EV-DO RevA mode: 3.1 Mbps FL/1.8 Mbps RL • Simultaneous Equalization and Rx Diversity on all bands, except for GSM/GPRS/EDGE CPU SIM • GSM/GPRS/EDGE: 850/900/1800/1900 MHz • UMTS/HSDPA/HSUPA/HSPA+: 800-850/900/1900/2100 MHz and AWS band (1700/2100 MHz) (B1, B2, B4, B5, B6, B8) • CDMA 1xRTT/EV-DO rev0/EV-DO revA: 800/1900 (BC0, BC1) Rx Diversity Visual feedback GPS Description
CG0192-11897 价格&库存
很抱歉,暂时无法提供与“CG0192-11897”相匹配的价格&库存,您可以联系我们找货
